Just a heads up. https://support.spotify.com/us/listen_everywhere/on_speaker/why-cant-i-use-the-spotify-app-on-my-speaker/ Its a bit worrisome that devices can so easily be crippled nowadays. A vinyl player, CD-player and tape player amongst other devices can still be used, even if it means only using old kinds of media. But in this case it will be easy to add an auxiliary unit but it will take a way the entire reason for the screen - which makes up the reason to even have a BeoSound 5.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I'm guessing thats the larges problem with the new streaming systems, the vendor is dependent on a 3:rd party service provider who could remove support of their services at any time.It's a drawback for me as a BS5 owner, but what scares me more is when support for .Net Radio are going to be removed.Hopefully it will take a while since, as I know it, it's B&O who provides the list och streaming radio channels to the device.
Some people say "If you can't hold it, you don't own it" and that is also true in the music world, physical media such as Vinyl or CD is far future proof than the new streaming world.
It would be nice if B&O would consider adding support for Spotify Connect or AirPlay as an update for the BS5 users, but I will not hold my breath for that to happend.
you can have airplay on a beomaster 5 , you just have it install a little software on it.
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
olvisab:you can have airplay on a beomaster 5 , you just have it install a little software on it. beolab 5, beolab 10, beolab 5000, beolab 8000 mk2, beolab 3500, IWS 2000, beovision 7 55 mk2, beotime, beogram 7000 white mmc2, beosound ouverture, beosound essence and the collection continues...
my spotify is not working anymore.. the thing is that I bought a BS5 with this feature and now.. it is gone.. B&O should solve this problem!
They even remove Spotify in the B&O TVs which makes our customers very mad.
