Beosound 3000 connection question
This post has 4 Replies | 2 Followers
DavidE
Posts 3
DavidE Posted: Mon, Jul 24 2017 9:01 PM
Hi
We have a Beosound 3000, Beovision 7-40 etc.
We have an airport express plugged into the Beosound 3000 Aux port so we can stream music from Apple Music.
We would really like to buy and connect a turntable as well. But we don't know how to connect it as we are already using the Aux port. Can we get a splitter or the like? Or could we plus into the power link sockets on the Beosound 3000 or a socket on the Beovision 7 somehow?
grateful for any help and advice.
Thanks David
MediaBobNY
Greenwich Village, NYC
Posts 1,106
B&O Aux Expander here.  Has 4 female DIN inputs in back - see last photo.  Look for a turntable with a built-in RIAA Phono Preamp.  If it doesn't have one you'll have to purchase an external one.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi David,
Welcome to Beoworld!  An even simpler solution is this 2 way Aux input splitter, which will allow the Airport Express and turntable to share the Aux socket (only one device can be played at once):-
http://soundsheavenly.com/bang-olufsen/11--aux-y-7pin-.html
As mentioned above, the best option is to look for a later Beogram that has a built in RIAA pre-amp, otherwise you will need an external pre-amp for the turntable.  You can see a full list of which Beogram models need a separate pre-amp here:-
http://www.soundsheavenly.com/faq/question/beogram-turntables-need-external-pre-amplifier-kit/
Kind regards, Steve.
Steve.
DavidE
Posts 3
DavidE replied on Sun, Aug 6 2017 8:50 PM
Thanks all that's really helpful. Back to the world of vinyl I come!
DavidE
Posts 3
DavidE replied on Sun, Aug 6 2017 8:51 PM
Page 1 of 1 (5 items) | RSS
