MasterLink Gateway and Samsung Smartthings
Kent
Pennsylvania, USA
Posts 25
Kent Posted: Thu, Jul 27 2017 3:41 PM
Does anyone know if it is possible to integrate Samsung's Smartthings with MasterLink Gateway?  Has anyone tried?
TWG
Posts 1,672
TWG replied on Fri, Jul 28 2017 8:36 AM
If the Samsung Smartthings understand http commands like the Philips HUE system it should be possible with a little programming.
If you find a documentation from Samsung it should look somehow like this:
https://developers.meethue.com/documentation/core-concepts
Kent
Pennsylvania, USA
Posts 25
Kent replied on Mon, May 28 2018 8:49 PM
There is an http api.  Now I just have to learn how to use it and how to progam the gateway to send the commands.
Kent
Pennsylvania, USA
Posts 25
Kent replied on Wed, May 30 2018 11:02 PM
I spent a couple of days learning about the web app api for Smartthings and I am able to turn lights on and off by sending http commands.  Now I just need to figure out how to configure that in the MLGW.
Does anyone have a driver file for a Philips HUE that they would be willing to share so I have an example to work from?
TWG
Posts 1,672
TWG replied on Thu, May 31 2018 7:02 AM
Maybe this will help you:
https://archivedforum2.beoworld.org/forums/t/13879.aspx
It's a german thread but it could be helpful, too
https://archivedforum2.beoworld.org/forums/p/18858/236335.aspx#236335
Page 1 of 1 (5 items) | RSS
