Does anyone know if it is possible to integrate Samsung's Smartthings with MasterLink Gateway? Has anyone tried?
If the Samsung Smartthings understand http commands like the Philips HUE system it should be possible with a little programming.
If you find a documentation from Samsung it should look somehow like this:https://developers.meethue.com/documentation/core-concepts
There is an http api. Now I just have to learn how to use it and how to progam the gateway to send the commands.
I spent a couple of days learning about the web app api for Smartthings and I am able to turn lights on and off by sending http commands. Now I just need to figure out how to configure that in the MLGW.
Does anyone have a driver file for a Philips HUE that they would be willing to share so I have an example to work from?
Maybe this will help you:
https://archivedforum2.beoworld.org/forums/t/13879.aspx
It's a german thread but it could be helpful, too
https://archivedforum2.beoworld.org/forums/p/18858/236335.aspx#236335
