Beovision 11
Jaypirate
Posts 3
Jaypirate Posted: Fri, Jul 28 2017 3:34 AM
Hi there, looking to set up sound mode default to MUSIC. Is this possible and how as that is 90% what I use it for. Regards
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 28 2017 6:56 AM
That is possible. What source do you want to play when you press MUSiC?
Assume you have a Beoremote One.
Jaypirate
Posts 3
Jaypirate replied on Fri, Jul 28 2017 8:44 AM
Hi Hiort,
as soon as I turn the TV on, the setup menu for sound automatically chooses DRAMA. This happens when I choose Radio, TV or A.Mem (Apple TV) on the remote. I want it to automatically choose Music in the setup menu instead.0
Thanks, Jay
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Jul 28 2017 9:10 AM
Jaypirate:
Hi Hiort,
Thanks, Jay
Ok, I understand.
You can change that setting for each source so that it
I'm not at home currently so I cannot guide you in detail. Have you got access to a user manual?
Marcello
Posts 213
Marcello replied on Fri, Jul 28 2017 9:52 AM
AFAIK, you have to do this for each source.
1. Go to MENU--> SOURCE LIST
2. Highlight the SOURCE for which you want to store a specific sound mode
3. Press the RED button (Setup)
4. You will get a screen with "Socket: HDMI x. Select ADVANCED SETTINGS
5. Highlight the first option "SOUND MODE" and press the RIGHT button on your remote
6. Highlight and select "MUSIC" (or any other mode")
7. You will be taken back to the Advanced settings screen and Sound Mode should now display the new mode that you just chose. Use the OK button on your remote to store the information. From now on, every time you select the source, you will get MUSIC by default.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Fri, Jul 28 2017 7:42 PM
I will give a mix anglo/french from my tv :
- menu + go
- list source + go
- choose your source + red on remote
- advanced settings + go
- mode sonore + right with remote stick (first line)
- choose music + go
- go again for memory
Voilà
Millemissen
Flensborg, Denmark
Posts 14,680
Sources have default settings, for example, sound and picture that suit most situations but you can change these settings if you wish. Select the source and select the ADVANCED SETTINGS menu.
When you configure a source, you can set a sound mode to be selected automatically each time you switch on the source. The setting is made in the ADVANCED SETTINGS menu under the SOURCE LIST SETUP menu.
Jaypirate
Posts 3
Jaypirate replied on Sat, Jul 29 2017 7:10 AM
Thanks all for your help, fixed!
 Regards
Page 1 of 1 (8 items) | RSS
