Hi there, looking to set up sound mode default to MUSIC. Is this possible and how as that is 90% what I use it for. Regards
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi Hiort,
as soon as I turn the TV on, the setup menu for sound automatically chooses DRAMA. This happens when I choose Radio, TV or A.Mem (Apple TV) on the remote. I want it to automatically choose Music in the setup menu instead.0
Thanks, Jay
Jaypirate:Hi Hiort, as soon as I turn the TV on, the setup menu for sound automatically chooses DRAMA. This happens when I choose Radio, TV or A.Mem (Apple TV) on the remote. I want it to automatically choose Music in the setup menu instead.0 Thanks, Jay
AFAIK, you have to do this for each source.
1. Go to MENU--> SOURCE LIST
2. Highlight the SOURCE for which you want to store a specific sound mode
3. Press the RED button (Setup)
4. You will get a screen with "Socket: HDMI x. Select ADVANCED SETTINGS
5. Highlight the first option "SOUND MODE" and press the RIGHT button on your remote
6. Highlight and select "MUSIC" (or any other mode")
7. You will be taken back to the Advanced settings screen and Sound Mode should now display the new mode that you just chose. Use the OK button on your remote to store the information. From now on, every time you select the source, you will get MUSIC by default.
Sources have default settings, for example, sound and picture that suit most situations but you can change these settings if you wish. Select the source and select the ADVANCED SETTINGS menu.
When you configure a source, you can set a sound mode to be selected automatically each time you switch on the source. The setting is made in the ADVANCED SETTINGS menu under the SOURCE LIST SETUP menu.
Thanks all for your help, fixed!
Regards
