Would love some sage advice before contacting a B&O store on the best way to update a present multi room set up listed below in current house as we prepare a move in early spring into a new build with a similar set up. Currently using an NL/ML convertor with 2 active and one passive kit. Sincerest thanks appreciated in advance.
Current system:
front room: Beovision Avant, 2014, Beosound 9000 and Beosound 5 with Beolab 9's
middle room/office: 2 Beolab 8000's and a Beolab 2 (active kit)
master bedroom: Panasonic and two Beolab 12-2's (active kit)
We also have Beoplay A6, M5 and Beosound 2 wireless speakers that participate via multi room. Will definitely keep the Beomaster 5 and use the Beosound 5 as a paperweight!!! Have not yet decided on the Beousound 9.
Thank you again for any guidance,
Gary
BeoNut since '75
That setup could effordless be transformed to a different location.
I didd not notice any mentioning of a NL/ML Converter - in case old and new is supposed to work together.
Maybe that is meant by 'connectivity hub'??? Otherweise I would not know what that is, either!
The most important thing before a move to a new location/house is to get the cabling well done/the infrastructure must be well considered.
elephant:Sorry I missed the bit about you already having a BLC I must be going blind 🙇
Oh, me too going blind!
So what is a 'connectivity hub' and what is it for?
The attached photo of a Beocore connectivity hub is attached below. Apparently this is part of the Beoplay 8 and the new The Shape that eventually will help an existing analog and digital combination system better perform together.
Gary:The attached photo of a Beocore connectivity hub is attached below. Apparently this is part of the Beoplay 8 and the new The Shape that eventually will help an existing analog and digital combination system better perform together.
