updating system advice needed for a new house
This post has 9 Replies | 1 Follower
Gary
Dublin, Ohio
Posts 108
Gary Posted: Sun, Jul 30 2017 4:35 PM
Would love some sage advice before contacting a B&O store on the best way to update a present multi room set up listed below in current house as we prepare a move in early spring into a new build with a similar set up. Currently using an NL/ML convertor with 2 active and one passive kit. Sincerest thanks appreciated in advance.
Current system:
front room: Beovision Avant, 2014, Beosound 9000 and Beosound 5 with Beolab 9's
middle room/office: 2 Beolab 8000's and a Beolab 2 (active kit)
master bedroom: Panasonic and two Beolab 12-2's (active kit)
We also have Beoplay A6, M5 and Beosound 2 wireless speakers that participate via multi room. Will definitely keep the Beomaster 5 and use the Beosound 5 as a paperweight!!! Have not yet decided on the Beousound 9.
Thank you again for any guidance,
Gary
elephant
AU
Posts 8,219
elephant replied on Mon, Jul 31 2017 11:42 PM
Hi Gary
Where is the passive kit used ?
At first I thought the simple solution was to replace the kits with Essence mk IIs; and explore connecting the Panasonic to the Essence's line-in.
However wanting to keep the BeoSound 5 (I agree it's a beautiful paperweight) means retaining some ML connections and looking to the BeoLink Converter NL/ML as a bridge (and maybe a second for the BeoSound 9000).
I strongly recommend you download the BLC's technical and spend a week studying its combinations and permutations.
BeoNut since '75
Gary
Dublin, Ohio
Posts 108
Gary replied on Tue, Aug 1 2017 12:14 AM
The passive kit was used for the patio speakers which will not be used once moved into new house. Simply looking for the best way to make analog and digital live in harmony! It has been mentioned to me to upgrade to a connectivity hub in place of the NL/ML convertor that I presently have.
elephant
AU
Posts 8,219
What is a connectivity hub !?!?!
Never heard of that before ...
BeoNut since '75
elephant
AU
Posts 8,219
Sorry I missed the bit about you already having a BLC
I must be going blind 🙇
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
That setup could effordless be transformed to a different location.
I didd not notice any mentioning of a NL/ML Converter - in case old and new is supposed to work together.
Maybe that is meant by 'connectivity hub'??? Otherweise I would not know what that is, either!
The most important thing before a move to a new location/house is to get the cabling well done/the infrastructure must be well considered.
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
Oh, me too going blind!
So what is a 'connectivity hub' and what is it for?
Gary
Dublin, Ohio
Posts 108
Gary replied on Wed, Aug 2 2017 1:29 PM
The attached photo of a Beocore connectivity hub is attached below. Apparently this is part of the Beoplay 8 and the new The Shape that eventually will help an existing analog and digital combination system better perform together.
Gary
Dublin, Ohio
Posts 108
Gary replied on Wed, Aug 2 2017 1:43 PM
elephant
AU
Posts 8,219
elephant replied on Thu, Aug 3 2017 12:59 PM
Gary:
Can't see the photo
And so far we have only had rumours of the shape components being used elsewhere
There is a rumour that parts of the shape are the next Essence (mark III)
Which would be wonderful
You must have wonderful contacts/ great supplier
BeoNut since '75
Page 1 of 1 (10 items) | RSS
