refoaming my Beovox Penta's - is it worth it?
This post has 5 Replies | 0 Followers
Scott
Ayrshire, Scotland
Posts 54
Scott Posted: Thu, Aug 3 2017 7:13 PM
Hi all,
I have a pair of Beovox Penta's which i picked up very very cheaply locally along with a Beomaster 5500 and CD5500.
There is foam rot on the surrounds of the mid range drivers. See attached photos.
Obviously i'd like to get the best out of the speakers but as the the foam doesn't appear to be that bad yet is it worth me trying to refoam? I am concerned about making it sound worse if i make a mess of the procedure.
Would it make a big enough difference to justify the cost and risk of doing it?
Beocenter 8500 / Beolab 4000 / Beosystem 5500 / Beolab 8000 / Beogram 2000 / Beosound 8 / Beovision 6-26 / Beovision MX4000 / Beomaster 1900-1 / Beovox CX50 / Beoplay H4 / Beoplay A1 / Beocom 1401 x2
Christophe
Cape Town
Posts 94
Hi, the first thing I did on my Pentas was re-foaming, it is a very easy procedure when you are patient and meticulous, I fitted them with rubber surrounds and the sound is obviously cleaner. There are several websites selling kits with rubber surrounds and glue, the only things you need (except for a glass that you can use to press evenly the surrounds after applying the glue).
Dave
Posts 40
Dave replied on Fri, Aug 4 2017 2:00 AM
Absolutely and definitely refoam. As they are they will just get worse.
ADU
Posts 12
ADU replied on Fri, Aug 4 2017 2:36 PM
Many years ago I did buy new mid speakers direct from Bang & Olufsen in Struer. But I dont think they still have the speakers for replacement.  But take a look her:
https://www.youtube.com/watch?v=lnc8JZF5ryI
The midrange is not the only problem. The crossover filters often also need replacement.
Scott
Ayrshire, Scotland
Posts 54
Scott replied on Sat, Aug 5 2017 10:14 AM
thanks everyone for the replies.
is there any guide on how to replace the crossover filters (and how would i know it this is also required?)
ADU
Posts 12
ADU replied on Sun, Aug 6 2017 11:39 PM
is there any guide on how to replace the crossover filters.........
Try this one:
http://egoh.com/2012/06/01/vintage-bang-olufsen-penta-restoration-project-twins-part-1/
http://egoh.com/2012/06/03/vintage-bang-olufsen-penta-restoration-project-twins-part-3/
I think there also is a guide here on Beoworld.com - maybe in the old forum?
Page 1 of 1 (6 items) | RSS
