I turned off the the tv, now everything is working.
Have just tried Uncharted 4 in HDR for some minuts, no problems. So yea I have not played for hours yet, but your problem might be the HDMI cable?
Are going to buy a Apple TV sunday for more testing.
Hi Fidse, how do you experience the drop outs on PS4Pro?
I think I also have them, the picture disappears, but the sound is there?
I tired to turn off HDR, no difference,
I then forced it to 1080P, that seems to have help.
Hmm then I rather keep my PS4 Slim...
Okay played 30min. with 2160p - YUV420,
I played GTA V so no HDR, but it works so far.
So try it out.
Emil Jensen:Okay played 30min. with 2160p - YUV420, I played GTA V so no HDR, but it works so far. So try it out. Beolab 20, Beolab 17, Transmitter 1
Fidse:
@ Fidse
What is your experience with the Viasat CA module ? Both with the LG and your previous TV.
BEOVOX141:@ Fidse What is your experience with the Viasat CA module ? Both with the LG and your previous TV.
I love the OLED picture but I also love the B&O sound, wanted an eclipse but couldn't stretch to the price, so made my own version and I think it looks better than the eclipse now :-)
I just need B&O to bring out a Beosystem 5
Beovision7:I love the OLED picture but I also love the B&O sound, wanted an eclipse but couldn't stretch to the price, so made my own version and I think it looks better than the eclipse now :-) I just need B&O to bring out a Beosystem 5
Fidse:Thanx fu21. That’s just not good enough! I would have connected it to the tv then, But then the cables won’t fit since i’ve already place my ps4 there as well, since that won’t work through the soundcenter either That they’ve got to get fixed. Having a fully equiped OLED screen and not being able to play Dolby Vision is just plain stupid....
I have got the Apple Tv to work now.
If you set it to SDR 4K as standard but set it to adjust to source automatic, it will work.
I have seen 6 episodes Altered Carbon in Dolby Vision 4K without problems.
Also I got the PS4 Pro to work. Though I must turn the Tv to the source before turning the PS4 on. Also the HDMI is set to output YUV420.
Do anyone know if it is possible to adjust the list in "List" so you have stand as first pick and so on?
Also if it is possible to hide a source, as Netflix, as I use the Apple Tv.
Emil Jensen:Do anyone know if it is possible to adjust the list in "List" so you have stand as first pick and so on? Also if it is possible to hide a source, as Netflix, as I use the Apple Tv. Beolab 20, Beolab 17, Transmitter 1
Emil Jensen:I have got the Apple Tv to work now. If you set it to SDR 4K as standard but set it to adjust to source automatic, it will work. I have seen 6 episodes Altered Carbon in Dolby Vision 4K without problems. Also I got the PS4 Pro to work. Though I must turn the Tv to the source before turning the PS4 on. Also the HDMI is set to output YUV420. Beolab 20, Beolab 17, Transmitter 1
Emil Jensen: Do anyone know if it is possible to adjust the list in "List" so you have stand as first pick and so on? Also if it is possible to hide a source, as Netflix, as I use the Apple Tv.
I don't think you can delete anything, and I haven't found a way to change the order of "list". However, you can re-order the "TV" list by going in to "settings", then "sound & beolink" then "sources". This gives you the list of sources and if you hit "edit" you can re-order them, and this new order is reflected in the remote.
Stan
Viasat Cam modulet....
På dansk så tråden bliver forstyrret mindst...
Kan du ikke lige dele data på TV2 HD jeg kan simplelt hen ikke finde den!
Viasat siger 11,345mHz men den er der ikke, og på Lyngsat.com kan jeg heller ikke finde noget.
So far it is not possible to reorder the items behind LIST I was told by my dealer. However from my opinion this is one of the top3 issues for the Eclipse to solve. Another one is to add some Eclipse functionality in the App (i.e. stand, sound, speakers).
Beofan with current setup Beovison Eclipse 55, Beosound 35, Beolab 6000, Beolab 11, Beoplay A9 Mk4, Beoplay E6
BEOVOX141:@ Fidse Viasat Cam modulet.... På dansk så tråden bliver forstyrret mindst... Kan du ikke lige dele data på TV2 HD jeg kan simplelt hen ikke finde den! Viasat siger 11,345mHz men den er der ikke, og på Lyngsat.com kan jeg heller ikke finde noget.
@ Fidse og andre der anvender Viasat?
Husk jeg har et helt andet chassis (7-55).. Den kender ikke viasat! Men finder 400 andre kanaler.
Det er meget underligt for TV2 HD er den eneste kanal der umiddelbart mangler.
Og hvad er endnu mere underligt er TV2 HD IKKE kan findes på lyngsats kanalliste, et eller andet sted må den vel være!
Derfor leder jeg med lys og lygte efter frekvens/symbolrate/polarisering for TV2 HD
Fidse: BEOVOX141: @ Fidse Viasat Cam modulet.... På dansk så tråden bliver forstyrret mindst... Kan du ikke lige dele data på TV2 HD jeg kan simplelt hen ikke finde den! Viasat siger 11,345mHz men den er der ikke, og på Lyngsat.com kan jeg heller ikke finde noget. Jeg havde samme problem med flere kanaler. Du skal gå i indstillinger - billede & programmer - kanaler - kanalindstillinger og så vælge VIASAT under programtilstand. Så burde de alle være der.
Du skal gå i
Ik kan anders ook wel de lekkere Brusselse wafels aanraden! Echt wel de moeite!
BEOVOX141: @ Fidse og andre der anvender Viasat? Husk jeg har et helt andet chassis (7-55).. Den kender ikke viasat! Men finder 400 andre kanaler. Det er meget underligt for TV2 HD er den eneste kanal der umiddelbart mangler. Og hvad er endnu mere underligt er TV2 HD IKKE kan findes på lyngsats kanalliste, et eller andet sted må den vel være! Derfor leder jeg med lys og lygte efter frekvens/symbolrate/polarisering for TV2 HD Fidse: BEOVOX141: @ Fidse Viasat Cam modulet.... På dansk så tråden bliver forstyrret mindst... Kan du ikke lige dele data på TV2 HD jeg kan simplelt hen ikke finde den! Viasat siger 11,345mHz men den er der ikke, og på Lyngsat.com kan jeg heller ikke finde noget. Jeg havde samme problem med flere kanaler. Du skal gå i indstillinger - billede & programmer - kanaler - kanalindstillinger og så vælge VIASAT under programtilstand. Så burde de alle være der.
Not sure they eat belgian waffles in Denmark - they are more into smørrebrød.
kuyttendaele:Ik kan anders ook wel de lekkere Brusselse wafels aanraden! Echt wel de moeite!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Just ordered an Eclipse 55" with Oak cover and wall bracket. It will replace my beloved 11-55. My BeoLab 9's have to go aswell. Boy have I enjoyed those! But times have changed and we need something lighter in our livingroom. I am very curious about the difference in sound between 5.1 from BV11+BL9+S8 and now Eclipse+S8 only. Delivery within 14 days. I have not bought brand new BeoVision since BV 8-40. I can't wait!
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Beoberg:Just ordered an Eclipse 55" with Oak cover and wall bracket. It will replace my beloved 11-55. My BeoLab 9's have to go aswell. Boy have I enjoyed those! But times have changed and we need something lighter in our livingroom. I am very curious about the difference in sound between 5.1 from BV11+BL9+S8 and now Eclipse+S8 only. Delivery within 14 days. I have not bought brand new BeoVision since BV 8-40. I can't wait! BeoVision 11-55 MKI (primary), BeoLab 9 (front), BeoPlay S8 (sub+rears), BeoLab 3500 (dining room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 1 old (leisure room), BeoSound 3 (workshop), 2x BeoPlay S3 (PC), BeoLit 12 (kitchen), BeoPlay A1, BeoPlay P2 (everywhere), BeoPlay H2/H3 (on the go)
Hi Fidse. Thank you for your respons. I am also quite sure that I will not regret my decision. I do have a sub in the form of the S8 main unit
Great to hear you bought yourself a new Eclipse and with the new oak cover. If you would like something "light" in regards to speakers, have you tried Beolab 3? or even wall hanging Beolab 17?The Soundcentre has plenty of sound for the TV alone. I had the Avant before my Eclipse and it needed a subwoofer, not so sure of a subwoofer is necessary at first. I mean if you want a full experience then go for a subwoofer but if you want something light in the living room.
//EA
Beo in white is my thing
Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
ErikVonAgnar:Great to hear you bought yourself a new Eclipse and with the new oak cover. If you would like something "light" in regards to speakers, have you tried Beolab 3? or even wall hanging Beolab 17? The Soundcentre has plenty of sound for the TV alone. I had the Avant before my Eclipse and it needed a subwoofer, not so sure of a subwoofer is necessary at first. I mean if you want a full experience then go for a subwoofer but if you want something light in the living room. //EA Beo in white is my thing Currently own: BeoVision Avant 55", BeoLab 5, BeoLab 18, BeoRemoteOne, BeoPlay V1-32", BeoRemote4, BeoSound 3200, BeoGram 6500 (MMC-1), BeoLit 15, BeoPlay A1, LC2, BeoVision MX7000 and BeoLab 3
Hi Eric
I have had the BeoLab 3's along with a BL11 when I had the BV 8-40. Nice speakers! As I wrote earlier I have the S8 2.1 set so I will still have 5.1 as the Eclipse will serve right, left and centre and the S8 will be rears and sub.
Best regards,
Frederik
ErikVonAgnar: Great to hear you bought yourself a new Eclipse and with the new oak cover. If you would like something "light" in regards to speakers, have you tried Beolab 3? or even wall hanging Beolab 17?The Soundcentre has plenty of sound for the TV alone. I had the Avant before my Eclipse and it needed a subwoofer, not so sure of a subwoofer is necessary at first. I mean if you want a full experience then go for a subwoofer but if you want something light in the living room. //EA
Fun to see that so many forum members have embraced the Eclipse after all
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort: Fun to see that so many forum members have embraced the Eclipse after all
Once you've seen (and hear) the Eclipse live you are sold
Beofan67: Hiort: Fun to see that so many forum members have embraced the Eclipse after all Once you've seen (and hear) the Eclipse live you are sold
Thats the experience I had :) Don´t have the funds available for an upgrade currently. And Eclipse cannot integrate to Moment like the BV11 I have.
I have had my Eclipse 65 for a month now. I am very satisfied with it. I had before a Beovision 7-55 Mark II and was "afraid" that the PQ on the Eclipse not was on par with 7-55 MkII. But I was wrong. I can say that all parameters regarding PQ is at least on par with 7-55 mkII (when looking at 720 p, 1080i and 1080P) and there is of course 4K movies which is outstanding in PQ.
I have put a lot of efforts in calibrating the PQ. There is a lot of possibilities in the Eclipse. Now I am very pleased. But I recommend NOT to use the eclipse with the "ECO" mode which is standard for the Eclipse.
I was also afraid that there was some software-bugs in the Eclipse that I have read on this forum. But after a lot of SW-updates I can say that the Eclipse is free of SW-problems now and works like charm. It is as good as my old BV 7-55 Mk2 which also was free from SW-problems.
Finally: I am very pleased totally with NO complaints at all. I have also two Beoplay A6 as multiroomspeakers (in two other rooms) and the multiroom-system works perfect with the B&O-app.
So if anyone is worried about software problems as other earlier Beovisions had (BV14 and Avant NG), there is NO such things in the Eclipse and the Beoplay A6 if combined together in a multioom setup. The Beoplay A6 got a new softwareupdate a couple of days ago which makes the A6 very stable and the Cast-functions works perfect.
Have a nice weekend!Best RegardsMartin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Hi Martin
Agree fully. But from my point of view some functionalities in the remote one like mybutton functionality and change order behind the LIST menu should be fixed and added. And in the App the option to change BV stand or speaker settings would be nice. But this will come I rely on.
Hello to all you Eclipse owners.
‘Now that the Oak speaker grill (Lamella) has officially been released, how many are going to rush out and buy one?
Yep, and for the 18s
Martin:But I recommend NOT to use the eclipse with the "ECO" mode which is standard for the Eclipse.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
phirstpro: Hello to all you Eclipse owners. ‘Now that the Oak speaker grill (Lamella) has officially been released, how many are going to rush out and buy one?
No not for me. I like the Eclipse fully black.
I wonder how the panel would match with the Beolab wooden panels. Looking from the picture the full wooden front is not built up with single panels like it is for the BL and the BV14 for instance.
But maybe in live it is amazing - like the Eclipse is .
A center view
