BEOVISION ECLIPSE
This post has 2,468 Replies | 20 Followers
Emil Jensen
Denmark
Posts 766
From the right side
Emil Jensen
Denmark
Posts 766
I have used books to cover the cable mess. Still missing to cover the last 10cm.
I have installed a 3m HDMI and USB she cable, so I can plug in without removing the covers on the TV.
Emil Jensen
Denmark
Posts 766
As I wrote in another thread, DTS-HD is now supported
Emil Jensen
Denmark
Posts 766
As I was setting the TV up, it became very clear that the panel is far from a stock LG C7, all the back panel have been altered, so it match the B&O style, and most important you can hide the cables, which is not possible from most other brands. But in generel a joy to assemble the TV, and much lighter then the BV7 and Avant :)
What I enjoy most with the TV is the simple control with the Beoremote, and the electric stand. Worth the money, and beats the very good Avant.
And also my Beolab 20 sounds much better now, compared running them with the Marantz.
elephant
AU
Posts 8,219
Emil Jensen:
Great setup Emil ....
How do the BL20s sound with the Eclipse ?
Are you running a 3.0 setup for video - or are you lucky enough to have built a 5.x setup ?
Do you use just the BL20s for audio ?
BeoNut since '75
BEOVOX141
Denmark, West
Posts 711
Emil Jensen:
As I was setting the TV up, it became very clear that the panel is far from a stock LG C7...
Hi Emil,- Please elaborate. What else is different apart from the back cover?
Any chance of a full picture of the type label on the panel, less the serial number of course. Big Smile
Emil Jensen
Denmark
Posts 766
elephant:
Emil Jensen:
I only have a 3.0 setup. No need for a subwoofer, the Beolab 20 is plenty.
I have had surroundsound many times before, And I must say that the effekt is not that great in my opinion.
Anyways I am not getting surround in the apartment I am in now, maybe later on.
When I listen to Deezer or Tune in I only use the Beolab 20, much better effekt. In video I use all speakers.
And the sound of the Beolab 20 is just great with the Eclipse, much better then before, it is a fantastic speaker.
Emil Jensen
Denmark
Posts 766
BEOVOX141:
Emil Jensen:
Else then the backcover, which is 50% of the panels design, the software is very different.
You have the sound, Source and Stand setting integrated  in the TV. In my view the software is as much B&O as the Avant, you just have the ekstra Software from LG also.
The B&O settings on the Eclipse is also better, then on the Avant.
elephant
AU
Posts 8,219
elephant replied on Sun, Mar 4 2018 10:54 AM
Thanks Emil for all the explanations and clarifications !
BeoNut since '75
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Sun, Mar 4 2018 11:13 AM
Emil Jensen:
Beolab 20, Beolab 17, Transmitter 1
Thanks for that pic Emil, was waiting for it for a long time.
Sound Center made in Czech.
tigerisak
Posts 124
tigerisak replied on Tue, Mar 6 2018 12:50 PM
Anyone else that has experienced problems with the remote since yesterday? I cant choose sources anymore it just shows "TV" thats all. Tried to do a factory reset on the remote but didn't solve it. Ideas?
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Mar 6 2018 4:20 PM
When you press "LIST" does it show "Beovision Eclipse" at the very top of the remote's screen?  I was messing with my remote the other day, and somehow this "product" setting got changed to a different value which then changed the LIST, TV and Music button behavior.  You can re-select Beovision Eclipse" under LIST->SETTINGS (somewhere under here, near the "Factory Reset", but I don't have my remote in front of me so I can't tell you exactly where).
Otherwise, perhaps the remote is no longer paired with the TV.  I think you can view remote pairings under the SETTINGS application on the BV.  Try re-pairing the remote with the TV because the menu items that show up under "TV" are sent from the BV to the remote.
Stan
Fidse
Posts 175
Fidse replied on Tue, Mar 6 2018 9:39 PM
It’s probably just me who’s either blind or dumb....
But can anyone tell me, how to connect my H9i’s to my Eclipse (wireless)?
phirstpro
Posts 67
phirstpro replied on Tue, Mar 6 2018 11:24 PM
Fidse:
i don’t think you can as I was told by the engineers who insmine that the Eclipse does not have a suitable Bluetooth transmitter  the only Bluetooth it had is for the remote
Fidse
Posts 175
Fidse replied on Wed, Mar 7 2018 8:00 PM
So i just bought the top model 10.300€ TV and the top model 510€ headphones from the same company, and i can’t connect these two, without using a cable like it’s 1992?
I simply refuse to be that.... otherwise, boy do i feel dumb...
phirstpro:
phirstpro
Posts 67
Fidse:
So i just bought the top model 10.300€ TV and the top model 510€ headphones from the same company, and i can’t connect these two, without using a cable like it’s 1992.
That’s about right. It was suggested that I buy a Bluetooth transmitter and plug it into the Eclipse!
On another note. We have two pairs of top of the range B&O headphones but cannot use them together on Bluetooth as the iPhone cannot determine which is which and comes up with an error or switches the other pair off!
happy days!
Fidse
Posts 175
Fidse replied on Wed, Mar 7 2018 8:25 PM
Jesus Christ...
I heard some of the “software-horror-stories” before switching to B&O and this is probably somewhat in the minor issues departement, but damn, it’s dumb...
If this is indeed true, I’m gonna twist my dealers arm and make him give me a bluetooth transmitter. I bought the headphones, more or less, just to be able to watch football games at night when the baby os asleep. A pretty hefty pricetag just for that, But i really thought it would be the easiest solution to just buy B&O’s headphones and that it would just be plug-and-play.
But f**k me...
It really is PLUG-and-play Sad
phirstpro:
happy days!
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 7 2018 8:45 PM
Surely the dealer explained that the headphones you have can’t pair with multiple devices?
Or is it the TV that has the one only limitation/ memory?
I thought about a BT transmitter for my Avant- but my dealer advised against. They’re generally too unreliable from his experience.
Bluetooth has its limitations - it’s been widely adopted recently but really only works well in simple cases in my view.
I tried a B&O pair with a BV14, and like others who did similarly, the lack of volume/ power made them useless. It was astonishing.
Fidse
Posts 175
Fidse replied on Wed, Mar 7 2018 8:51 PM
Actually the H9i CAN pair with mutiple devices, it’s part of the upgrades you get from the H9, but i don’t see how that’s relevant here?
The problem is that the Eclipse apperantly don’t have the possibility to connect to bluetooth headphones. I don’t really care about high volumes, as I’m only gonna listen to Carsten Werge and Per Frimann acting like they know all about football, i keep them at low volume anyway 😃
As for reliability, i have absolutely no problems when using them with my Iphone via bluetooth, works like a charm!
Sandyb:
phirstpro
Posts 67
Sandyb:
We have two pairs of Bang & Olufsen Bluetooth headphones, H9’s and H8’s  each being connected to a separate iPhone.  If both headphones are switched on both iPhones get confused and end up stopping both headphones! Neither of the headphones will connect to the Eclipse!  We usually end up connecting the headphones to the iPhone by the 3.5mm lead/jack.
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 7 2018 9:02 PM
Limitations of the TV then, that is unfortunate I’m sorry to hear that
And of course many people have few issues with BT headphones, but many people and many models do.
My only point about volume was to illustrate an example of the issues one can face. The low power of the BV14 with a pair of headphones just served to illustrate how easily a simple thing can be undermined
But of course if they give you a transmitter, then you may have some joy
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 7 2018 9:10 PM
Indeed, very much my point
Throw any non simplistic scenario at BT, and it all goes wrong
elephant
AU
Posts 8,219
Sandyb:
@Sandyb @Fisde
I use my B&O BT ANCs paired with the Apple TV.
I know that doesn’t solve the sports issue.
So just a thought for other material.
BeoNut since '75
Fidse
Posts 175
Fidse replied on Wed, Mar 7 2018 10:03 PM
Hmm, that’s not a bad idea!
I’ll have to check though, if the PQ of the Viaplay stream is satisfying for me to watch. I’m very happy with the PQ from my satelite signal from Viasat.
But thanks for the heads up, it could be a solution. Not that it makes B&O look any better, it’s still a dumb ass problem, they’ve created...
elephant:
@Sandyb @Fisde
So just a thought for other material. BeoNut since '75
KMA
Posts 621
KMA replied on Wed, Mar 7 2018 11:56 PM
Sandyb:
Limitations of the TV then, that is unfortunate I’m sorry to hear that.
I wonder why?
I can pair AKG's bluetooth headphones and even a rather cheap pair of Procaster headphones to my LG 7-series OLED without any issues.
Eclipse has the same TV part. How is it possible that in the B&O LG/SoundCenter combo bluetooth headphones do not work?
Unsure
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
lassfi
Posts 13
lassfi replied on Thu, Mar 8 2018 7:43 AM
Hey Fidse
I'll write following in Danish about your headphone problem.....
Hej Fidse
Jeg har selv et par BeoPlay H8 som jeg ønskede at bruge trådløst fra min PC. Kontaktede B&o support og de anbefalede Creative BT-W2 Transceiver / USB stik, som man sætter i et ledigt stik. Det fungerer stadig perfekt, dog lover B&o ikke at den fungerer med alle apparater. Prisen på den er ca. 40 euro, så det er en beskeden investering.
Her er et link til Creative, så kan du læse lidt :
http://dk.creative.com/p/sound-blaster/creative-bluetooth-audio-bt-w2-usb-transceiver
Da dit Eclipse tv har flere usb tilsutninger fylder det jo ikke nær så meget som de andre forslag der har været i forummet. God fornøjelse   :o)
Lasse
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Mar 8 2018 3:32 PM
KMA:
Not exactly an answer, but from looking at how one does this with a standard LG tv, the bluetooth is part of the "audio output" of the TV (you go into the "audio output" settings, etc.).  In the case of the Eclipse, all of the audio output is handled by B&O.  Apparently B&O didn't think this was important (or there's a technical reason why BT wouldn't work with the sound center).
phirstpro
Posts 67
Stan:
KMA:
Probably the same reason the WiFi is rubbish on the Eclipse. Some quite serious misgivings here by B&O. Not to mention the curtains being missing. When switching off it looks and feels like it has just crashed out very abruptly!
Sandyb
Posts 2,186
Sandyb replied on Thu, Mar 8 2018 5:00 PM
No doubt, a product of the modular approach taken to the Eclipse.
But in the end, shows that it was put together rather quickly - and the missing Bluetooth is surely an oversight?
Because how difficult can it be to put in a BT transmitter to the sound centre.
But given how rubbish the BT was in the BV14, maybe a good thing they left it out!
Fidse
Posts 175
Fidse replied on Thu, Mar 8 2018 5:29 PM
I spoke to my dealer today. He is contacting his installer who owns an Eclipse himself, if anyone got an answer, it’s got to be him. I’ll post the answer here when i get it. I’m not very optimistic though my dealer was certain it could be done.
elephant
AU
Posts 8,219
Sandyb:
Quickly ?!?!?
Doesn’t the strategic alliance go back the days of Tue ?
I felt we waited two years for this product !
BeoNut since '75
Sandyb
Posts 2,186
Sandyb replied on Thu, Mar 8 2018 5:42 PM
waiting a long time doesnt necessarily mean the product had a long development time....
leaving out BT seems either (a) an oversight or (b) a strange but deliberate omission.
If its (a), that suggests the product development was a bit lacking or a bit hurried.
If its (b) i'd love to know why BT was deliberately left out, assuming this is indeed the case (i.e. no BT)
BEOVOX141
Denmark, West
Posts 711
It's down to the architecture, which for the Video & Video sound part is : LG.
No more no less!  Even the Eclipse manual says: "LG describes..."
Face it: The days of The BeoSys are gone and when you cant touch the video part, compromises are inevitable.
FunFact : The LG TVs usually have a VERY comprehensive Service menu, But The Eclipse is not a stock C7, - or is it ? Whistle
Let the games begin.
Millemissen
Flensborg, Denmark
Posts 14,680
elephant:
Sandyb:
Quickly ?!?!?
I heard about an LG/B&O tv round about one and a half years before it actually hit the shops.
Of course B&O could not use the stock LG audio software (which includes BT-out).
That would have meant, that you would only get sound from the sources of - or connected directly to - the LG tv-part.
How about waiting for some kind of official explanation, why there is no output.....from the SoundCenter.
phirstpro
Posts 67
I for one would love to get an "official explanation" but I'm not convinced we're ever going to get one. I've been waiting some considerable time already without a hint of an answer!
PBSH
Marcello
Posts 213
phirstpro:
PBSH
You won’t get one or they will tell you it’s by design, or maybe it’s the same obscure reason why the BV11 does not have a headphones jack - I gave up trying to figure out B&O’s feature implementation process...
BT output is part of the LG TV so you can only send audio via BT from the sources connected to the pane itself, not the Soundcenter.
Marcello
Posts 213
phirstpro:
Strange. My wife and I are in the same situation, but as long as you pair each headphone to a single device (you cannot rename them so you will always see “Beoplay H7” for example) our idevices di not get confused, we often use them at the same time (until we kick the baby out of our room!).
We also connected two BT adapters to the BV10 headphone jack and while the quality is not great (lot of white noise) it works.
Marcello
Posts 213
Emil Jensen:
I was not aware of that. Even B&O official website does not mention it... crazy.
https://support.bang-olufsen.com/hc/en-us/articles/208692569-Media-files-smartphones-and-tablets
Millemissen
Flensborg, Denmark
Posts 14,680
Marcello:
Emil Jensen:
For what would you need this decoding capacity in the SoundCenter?
Marcello
Posts 213
Millemissen:
Marcello:
Emil Jensen:
Many Blu-Ray nowadays are DTS-HD Master Audio (or Dolby TrueHD, still unsupported by B&O).
Page 48 of 62 (2469 items) « First ... < Previous 46 47 48 49 50 Next > ... Last » | RSS
