BeoSound 5 & Spotify
This post has 20 Replies | 2 Followers
Sjock601
United States
Posts 43
Sjock601 Posted: Thu, Aug 10 2017 4:29 PM
I am no longer able to access Spotify on the BeoSound 5.  I guess it is no longer supported.  Is there another music streaming system that is supported?  If there is, how do I access the app to get it working on the BeoSound 5?
Duels
England
Posts 2,553
Duels replied on Thu, Aug 10 2017 4:41 PM
Sjock601:
There are other threads on this topic but the simple answer is no it is no longer supported (since June) and no there is no other supported streaming service.
B&O will provide a free of charge chromecast device and appropriate connectors through your dealer but this doesn't appear to have been widely publicised. I have ordered mine today and am keen to see how it sounds and works.
Sjock601
United States
Posts 43
Sjock601 replied on Thu, Aug 10 2017 6:53 PM
Thanks Duels,  I will look into the chromecast device.
fixingit
Posts 22
fixingit replied on Sun, Jan 14 2018 8:19 PM
take a look at this thread http://archivedforum2.beoworld.org/forums/t/29275.aspx
ECF
Malmö - Sweden
Posts 35
ECF replied on Mon, Feb 12 2018 12:56 PM
Hi
I found this guy on e-bay (http://r.ebay.com/JVLFqP) and decided to try - and it worked! The job took less than 5 minutes and he was very detailed and professional in his instructions. I now have Spotify working as it used to do! Big Smile
On top of this I succeeded in replacing my HDD with a SSD and the system is now superfast!
Erik
Millemissen
Flensborg, Denmark
Posts 14,680
That guy also had a thread here, where he offered his (to pay for) service.
Please keep us updated about for how long this ‘fix’ will work.
Nidi
Posts 46
Nidi replied on Tue, Feb 13 2018 8:21 AM
Hallo, ich habe mir die Spotify Lösung von Fixingit auch via ebay gegönnt. Der von ihm aufgespielte Patch funktioniert wunderbar. Das Spotify auf der Beosound 5 funktioniert wieder wie gewohnt. Covers werden wieder wie früher schön auf dem Display angezeigt. Einzig das Problem mit den von Spotify kreierten Playlisten ist vorhanden. Dies lässt sich aber einfach beheben, indem diese Listen einfach gelöscht werden.
Im Weiteren kann falls installiert über A.AUX auf das bereits bekannte Spotify-Connect zugegriffen werden. Mir macht die Anlage so wieder richtig Spass, so dass ich nun auf SSD umrüsten werde.
Nidi
Posts 46
gysse2004
Hellerup
Posts 192
gysse2004 replied on Tue, Feb 13 2018 6:46 PM
I to had this done, works really well. Did break once, but had it done on “warenty” and now it is up and running again.
Br
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Beofrank
Posts 79
Beofrank replied on Tue, Feb 13 2018 7:57 PM
Maybe b & o software can release an update so that it will work for everyone.
Apparently it is not difficult to make this.
And so meets his customers
fixingit
Posts 22
fixingit replied on Tue, Feb 13 2018 11:28 PM
Beofrank:
Lol - just because it only takes a few minutes to install, does not mean it was “not difficult” to make it. Took me many months of reverse engineering and software development to find a solution. B&O can not provide this patch as they can not get a new commercial Spotify license based on libspotify.
What B&O could do (and should do) is to either provide a software upgrade with Deezer support as they have in their newer products, or use the newer Spotify APIs, allthough I am not sure they offer a full libspotify replacement yet....
beolion
Posts 485
beolion replied on Wed, Feb 14 2018 9:44 AM
fixingit:
Agree on that one. At least make sure that customers are not let behind with nothing.
But it also highlights the problem at B&O and software strategy and competencies.
Nidi
Posts 46
Nidi replied on Fri, Feb 16 2018 8:52 PM
I have a Crucial MX300 525 built into my 10 years old Beomaster 5 today. The system works much faster now and makes great fun with the installed Spotify patch from Fixingit. The Covers make the BS5 beautiful.
ECF
Malmö - Sweden
Posts 35
ECF replied on Mon, Mar 19 2018 9:46 AM
The fix stopped working twice but within a day or two a new fix was in place - no extra charge. I am very happy.
Bart
Mallorca, Hamburg, Billund
Posts 15
Bart replied on Wed, Apr 11 2018 3:23 PM
Where can I get that patch?
Thanks,
Bart
BL8000, BL8002, BL4000, BL3, BL12.2, BS5, BS7000, BS9000, BS9500, BS2000, Ouverture
B&Ola
Stockholm
Posts 27
B&Ola replied on Thu, Oct 11 2018 9:14 AM
Has anyone bought this and still got it to work?
beolion
Posts 485
beolion replied on Thu, Oct 11 2018 3:00 PM
B&Ola:
It does not work anymore.
Only option is to use Chromecast with USB or install an old version of Spotify directly on BM5.
tc0fh
Posts 1
tc0fh replied on Tue, Sep 15 2020 4:25 PM
Hello!
Does the old version of Spotify on BM5 still work?
beolion
Posts 485
beolion replied on Tue, Sep 15 2020 10:58 PM
tc0fh:
Hello!
No. Spotify closed the API as I remember.
Edoardo
San Marino
Posts 163
Edoardo replied on Sun, Jul 18 2021 9:30 AM
I tried, but that link is no more working: it just takes you on eBay page, saying that the requested page is missing
Page 1 of 1 (21 items) | RSS
