I am no longer able to access Spotify on the BeoSound 5. I guess it is no longer supported. Is there another music streaming system that is supported? If there is, how do I access the app to get it working on the BeoSound 5?
Sjock601:I am no longer able to access Spotify on the BeoSound 5. I guess it is no longer supported. Is there another music streaming system that is supported? If there is, how do I access the app to get it working on the BeoSound 5?
Thanks Duels, I will look into the chromecast device.
take a look at this thread http://archivedforum2.beoworld.org/forums/t/29275.aspx
Hi
I found this guy on e-bay (http://r.ebay.com/JVLFqP) and decided to try - and it worked! The job took less than 5 minutes and he was very detailed and professional in his instructions. I now have Spotify working as it used to do!
On top of this I succeeded in replacing my HDD with a SSD and the system is now superfast!
Erik
That guy also had a thread here, where he offered his (to pay for) service.
Please keep us updated about for how long this ‘fix’ will work.
Hallo, ich habe mir die Spotify Lösung von Fixingit auch via ebay gegönnt. Der von ihm aufgespielte Patch funktioniert wunderbar. Das Spotify auf der Beosound 5 funktioniert wieder wie gewohnt. Covers werden wieder wie früher schön auf dem Display angezeigt. Einzig das Problem mit den von Spotify kreierten Playlisten ist vorhanden. Dies lässt sich aber einfach beheben, indem diese Listen einfach gelöscht werden.
Im Weiteren kann falls installiert über A.AUX auf das bereits bekannte Spotify-Connect zugegriffen werden. Mir macht die Anlage so wieder richtig Spass, so dass ich nun auf SSD umrüsten werde.
I to had this done, works really well. Did break once, but had it done on “warenty” and now it is up and running again.
Br
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Maybe b & o software can release an update so that it will work for everyone.Apparently it is not difficult to make this.And so meets his customers
Beofrank: Maybe b & o software can release an update so that it will work for everyone.Apparently it is not difficult to make this.And so meets his customers
Lol - just because it only takes a few minutes to install, does not mean it was “not difficult” to make it. Took me many months of reverse engineering and software development to find a solution. B&O can not provide this patch as they can not get a new commercial Spotify license based on libspotify.
What B&O could do (and should do) is to either provide a software upgrade with Deezer support as they have in their newer products, or use the newer Spotify APIs, allthough I am not sure they offer a full libspotify replacement yet....
fixingit: What B&O could do (and should do) is to either provide a software upgrade with Deezer support as they have in their newer products, or use the newer Spotify APIs, allthough I am not sure they offer a full libspotify replacement yet....
I have a Crucial MX300 525 built into my 10 years old Beomaster 5 today. The system works much faster now and makes great fun with the installed Spotify patch from Fixingit. The Covers make the BS5 beautiful.
Where can I get that patch?
Thanks,
Bart
BL8000, BL8002, BL4000, BL3, BL12.2, BS5, BS7000, BS9000, BS9500, BS2000, Ouverture
https://www.ebay.com/itm/B-O-Beosound-5-Spotify-OEM-activation/302615250912?hash=item46754647e0:g:kfsAAOSwvktaZ7Rm
Has anyone bought this and still got it to work?
B&Ola:Has anyone bought this and still got it to work?
Hello!
Does the old version of Spotify on BM5 still work?
tc0fh:Hello! Does the old version of Spotify on BM5 still work?
I tried, but that link is no more working: it just takes you on eBay page, saying that the requested page is missing
