Beogram 3400 and 1900 parts interchangeable?
Puddintane
USA
Posts 9
Puddintane Posted: Fri, Sep 14 2012 6:43 PM
Are any (or all) parts from a Beogram 1900 (other than, obviously, the chassis and dustcover) useable on a 3400? I'm thinking of the tonearm or any other internal components, mechanical or electronic. Thanks.
Puddintane
USA
Posts 9
Puddintane replied on Sun, Sep 16 2012 10:21 PM
Any advice/opinions at all?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Sep 16 2012 10:43 PM
They are basically identical. Only difference is that the Beogram 3400 was prepared for the fitting of a
CD-4 decoder.
Tonearm, mechanics etc. are all the same.
There's not a lot of electronics in these decks.
Puddintane
USA
Posts 9
Puddintane replied on Sun, Sep 16 2012 11:11 PM
Thanks for the info, Martin. Much appreciated.
zgrivells
Posts 1
zgrivells replied on Sun, Dec 9 2012 12:23 AM
Hi Martin
I recently received the Beogram 3400 from a friend that had it in his garage. I immediately connected and tried it but doesn't spin.
Do you have any suggestion how to fix it or what may be the problem?
The mechanics seem to work good because if i spin it with my hand (probably not very good to do it) the arm moves to the record and settles on it as also it goes back if I press stop button.
Thank you
Gretings
Søren Mexico
Mexico City
Posts 6,411
Are transport screws loosened, is the belt there, is the motor spinning ???
Page 1 of 1 (6 items) | RSS
