Liverpoolpete: I purchased a line in cable to connect the iPad direct to the moment. When I play from the Deezer app it shows HQ in the album artwork, not flac as has been reported elsewhere. I haven’t seen any change in the B&O app.
- Flere
smile and enjoy the moment
Deezer HiFi + ECM Catalogue on Deezer, what else?
mbolo01:Deezer HiFi + ECM Catalogue on Deezer, what else?
Flere:Is there an easy way to browse the ECM catalogue on Deezer
Flere: Is there an easy way to browse the ECM catalogue on Deezer?
I guess you have to pick record by record.
Maybe this link can help.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
BeoNut since '75
elephant:Playing HiFi FLAC on the Essence joined with a BLC nl/ml ... sadly the FLAC does not come through ... if I am to believe the UI BeoNut since '75
I’ve got a Beosound Moment, and there still isn’t an official update to allow Deezer Hifi (flac) to be played.
Does anyone know when this update will be available?
Thanks.
Beolab 5 Final Edition, Beosound Moment
Hello.
Does anyone have a tip on seaching for Hifi in Deezer?
Maniax: I’ve got a Beosound Moment, and there still isn’t an official update to allow Deezer Hifi (flac) to be played. Does anyone know when this update will be available? Thanks.
The B&O website says that the moment is compatible with Deezer Hifi. Guess we just need the 2.2 software to make this happen, lets hope it is not too long away
Normann:tip on seaching for Hifi in Deezer?
jimcaj: Normann: tip on seaching for Hifi in Deezer? There are some cool playlists, if you search for hifi
Do i need to play music on Deezer on the Bang Olufsen app, Beolink 2 app to play with HIFI quality? Or does it work to play it on the Deezer app, and cast/airplay it to a speaker/system.. ?
Normann:Do i need to play music on Deezer on the Bang Olufsen app to play with HIFI quality?
Does your BS Essence MKII is still working with FLAC?
I have the 1.15.17 software version an can not make it work.
It only works on my A9
I am sorry the question got posted 3 times and don't know how to delete them
Sorry Duplicated can't erase
Apologies
MexExec:Does your BS Essence MKII is still working with FLAC? I have the 1.15.17 software version an can not make it work. It only works on my A9
Flere:Is there an easy way to browse the ECM catalogue on Deezer?
The entire recording catalogue of ECM Records Is now available on the streaming services.
Justin:Any tips how I can confirm flac on the Moment?
mbolo01:For now, only the 2.2 beta version can handle Deezer HiFi. When playing hifi, the FLAC word follows the Deezer logo on in the JukeBox interface BS Moment, BL 18, BL 19, A6, M5, A1, H5
It should be easy to confirm if it is playing in higher quality. You should HEAR the difference.
I can't hear the difference on my speakers.
I can't hear the difference between Tidal HiFi and Tidal studio using H6 mk1 and mk2 with a headphone DAC.
So I just started to enjoy actually listening to music again instead of fiddling around with audio equipment and on-paper quality.
Not saying others can't hear the difference.
