I have a Beovison 8 with a DVB-C tv-box connected via HDMI. I cannot get the sound out of the masterlink and to my link rooms. I have set the BV8 in V.OPT 2. The Link rooms goes on when I push “TV” or “DTV” (DTV is where in tv-box is connected on HDMI) on the beo4 in the link room, but no sound.
Normal 0 false false false EN-US JA X-NONE
Is it because I cannot take sound from the HDMI and to masterlink? So if it should work, I connect via scart?
You cannot route the sound from a HDMI-connected source to the ML.
The source must be connected analog/via scart to the tv (as well).
Thank you. That makes sense. I must found out about my tv-box can send signal out on both HDMI and scart. Then I can choose the scart channel, when I will have sound in the link rooms.
But if it was built in - as in the Beovision 8-40 - it would be possible to distrubute the sound via masterlink?
Master123456789:But if it was built in - as in the Beovision 8-40 - it would be possible to distrubute the sound via masterlink?
BeoNut since '75
Thanks. I guess that your bv8-40 has upgraded the DVB-module.
Master123456789:Thanks. I guess that your bv8-40 has upgraded the DVB-module.
