Beogram 3400 cueing doesn't lift at end of record or when pressing Stop
Puddintane
USA
Posts 9
Puddintane Posted: Sun, Sep 16 2012 11:10 PM
Would someone please tell me how to troubleshoot a tonearm on a 3400 that doesn't lift either when STOP is pressed or even when it reaches the end of an LP? It does return, but it doesn't lift. I've looked inside, but I can't quite figure out how the lift mechanism works. Thanks.
Søren Mexico
Mexico City
Posts 6,411
Clean and lubricate, specially around the tonearm shaft and mechanism
Puddintane
USA
Posts 9
Puddintane replied on Sun, Sep 16 2012 11:56 PM
Thanks Soren Mexico. I've never worked on one of these tables before, so I'm a little unsure of what all that would entail. Would it need to be disassembled, and if yes, could you tell me where to begin--at least with the inside components? Or is this something simple that could be done by working through the bottom of the cabinet using some cotton-tipped swabs and applying a little oil? I took the bottom cover off, and I"m not altogether clear what makes the arm lift.
Søren Mexico
Mexico City
Posts 6,411
If you cant follow simple mechanics functions you should not take anything apart, but clean of all old grease and hardened oil and lubricate where you cleaned. If I remember right you do have a BM 1900, if that one works correctly open it and see if there are differences or broken parts in the 3400.
Here is what you are in for if you want to do it properly, this is not a 3400 but an older 1202, its just an example.
Page 1 of 1 (4 items) | RSS
