Beosound 5 Encore
This post has 11 Replies | 1 Follower
Normann
Posts 277
Normann Posted: Mon, Sep 17 2012 12:28 PM
Hi!
I'm a happy owner of an new Encore.. But i have one question, it seems that my music library are registered double? So every song comes two times...
Does anyone have an solution for this problem?
Normann
Posts 277
Normann replied on Mon, Sep 17 2012 7:54 PM
Hello ?
elephant
AU
Posts 8,219
elephant replied on Mon, Sep 17 2012 9:25 PM
Normann:
Hi!
Do you have your music stored in two places ( a primary drive and a back-up drive).
Is the BS5E "seeing" two network addresses ?
BeoNut since '75
Normann
Posts 277
Normann replied on Mon, Sep 17 2012 10:05 PM
I have a Nas drive with two hd.. One primary and one for backup.. But i am just using primary hd for my music.. I have never experienced that this has been any problem with other products before for example Sonos..
How have you done your setup?
mbee
Paris, France
Posts 1,842
mbee replied on Mon, Sep 17 2012 10:12 PM
If your NAS allows to select which shared folder the DLNA server scans, check that the back-up folder is NOT scanned.
Normann
Posts 277
Normann replied on Mon, Sep 17 2012 10:28 PM
Ok..I am running a readynas duo 2.. Do You have any clue were i can check this out? Is this a known problem?
I am quite new at this... Thanks for answering
Aussie Michael
Melbourne, AU
Posts 3,730
I would imagine that if your NAS is a one disk NAS like mine (I don't use the backup partition) that it would pick up all songs within that NAS.
I use a WD Mybooklive and I love it. When I purchased my encore it took a day for it to work looking for all the music.
Would you like me to check my encore by adding a hard drive and checking if it sees double ?
Normann
Posts 277
Normann replied on Tue, Sep 18 2012 2:52 PM
If you can do that it would by great..!
So let me get this right: If i have a Nas disk with two drives it will probably read from both of them, and if i have timemachine backup from my mac (and if it has some music stored on it) it would also read those songs? So some of my songs can be read three times ? :)
What do you guys recommend me to do?
Aussie Michael
Melbourne, AU
Posts 3,730
I'm not sure it will read your time capsule. It reads your other drive because it has a music server on it. The time capsule doesn't have this.
I have a time capsule and it doesn't read mine.
I will try the hard disk thing when I get my encore back from service. I was having a slight issue where by the stand by light would not come on, then the encore would lose power all together and I had to plug out of the power to repower. The last issue was I had the standby light on but the encore doesn't respond. So off to service after a few weeks of ownership lol.
You could always rescan your hard drive which sets it all up again. Let me know if you need instructions on this.
Also is all your album art available?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Sep 19 2012 8:30 PM
This is no BS5e issue.
Your mediaserver on your NAS register the files two times.
Which mediaserver is used?
Normann
Posts 277
Normann replied on Wed, Sep 19 2012 9:19 PM
I am using an ReadyNas duo 2.. I think it's a little bit strange, because the album art is just showing one time..
mbee
Paris, France
Posts 1,842
mbee replied on Thu, Sep 20 2012 8:16 AM
A common explanation could also be that if you have a ".cue" or ".m3u" playlist file with the content of the album in each album folder, your media server could display the songs 2 times : one time for the song file itself, and one time for its playlist reference.
Page 1 of 1 (12 items) | RSS
