Hi!
I'm a happy owner of an new Encore.. But i have one question, it seems that my music library are registered double? So every song comes two times...
Does anyone have an solution for this problem?
Hello ?
Normann: Hi! I'm a happy owner of an new Encore.. But i have one question, it seems that my music library are registered double? So every song comes two times... Does anyone have an solution for this problem?
Do you have your music stored in two places ( a primary drive and a back-up drive).
Is the BS5E "seeing" two network addresses ?
BeoNut since '75
I have a Nas drive with two hd.. One primary and one for backup.. But i am just using primary hd for my music.. I have never experienced that this has been any problem with other products before for example Sonos..
How have you done your setup?
If your NAS allows to select which shared folder the DLNA server scans, check that the back-up folder is NOT scanned.
diisign.com
Ok..I am running a readynas duo 2.. Do You have any clue were i can check this out? Is this a known problem?
I am quite new at this... Thanks for answering
If you can do that it would by great..!
So let me get this right: If i have a Nas disk with two drives it will probably read from both of them, and if i have timemachine backup from my mac (and if it has some music stored on it) it would also read those songs? So some of my songs can be read three times ? :)
What do you guys recommend me to do?
I am using an ReadyNas duo 2.. I think it's a little bit strange, because the album art is just showing one time..
A common explanation could also be that if you have a ".cue" or ".m3u" playlist file with the content of the album in each album folder, your media server could display the songs 2 times : one time for the song file itself, and one time for its playlist reference.
