Please be informed that I have updated the B&O Product Software List HERE in the WiKi section of the forum.
Regards Keith....
Hi Keith,
When you say Bluray Unit BODTBB52, does this mean that B&O have changed the bluray unit to a new one (was before BODTBB47) or is it just a software-upgrade?
RegardsMartin S
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Hi Räuber,
I have connected my BV 7-55 3D with Ethernet cable. But there is no software update for the Blurayplayer. I have tried the software update in the setup-menu in the blurayplayers menu. But there is no update available.
How do I install the new software myself?
/Martin
Hi Martin,
did you connect the Ethernet cable between Ethernet socket of the bluray player (not of the HD module) and your router? If so, check with your router software or in the settings menu of the bluray player whether the bluray player is really connected with the internet. The menu should show a new update available. Then you can start the update by pressing the green key (with old Beo4 you have to press thev green key twice).
/Räuber
There is just one Ethernet connection on the Beovision 7-55 3D, and this is for the Blurayplayer. I have also checked the settings-menu of the blurayplayer and it is really connected with the internet. BUT, there no update available. Have you made your update thru this ethernet connection?
