Software List Updated
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Keith Saunders Posted: Tue, Sep 18 2012 12:44 PM
Please be informed that I have updated the B&O Product Software List HERE in the WiKi section of the forum.
Regards Keith....
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Sep 18 2012 5:11 PM
Thanks Keith.
But please note the following in your list:
All Beovisions with build 224: The actual software build is 227,
All Beovisions with build 1105: Actual is build 1112 (audio problem solved),
Bluray unit: BODTBB52
Regards
Räuber
Sweden
Posts 357
Silver Member
Martin replied on Wed, Sep 19 2012 3:11 PM
Hi Keith,
When you say Bluray Unit BODTBB52, does this mean that B&O have changed the bluray unit to a new one (was before BODTBB47) or is it just a software-upgrade?
Regards
Martin S
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Sep 19 2012 4:03 PM
Hi Martin S,
BODTBB52 is just a software update, you can install it by yourself.
Regards
Räuber
Sweden
Posts 357
Silver Member
Martin replied on Fri, Sep 21 2012 7:48 AM
Hi Räuber,
I have connected my BV 7-55 3D with Ethernet cable. But there is no software update for the Blurayplayer. I have tried the software update in the setup-menu in the blurayplayers menu. But there is no update available.
How do I install the new software myself?
/Martin
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Sep 21 2012 11:44 AM
Hi Martin,
did you connect the Ethernet cable between Ethernet socket of the bluray player (not of the HD module) and your router? If so, check with your router software or in the settings menu of the bluray player whether the bluray player is really connected with the internet. The menu should show a new update available. Then you can start the update by pressing the green key (with old Beo4 you have to press thev green key twice).
/Räuber
Sweden
Posts 357
Silver Member
Martin replied on Fri, Sep 21 2012 3:24 PM
Hi Räuber,
There is just one Ethernet connection on the Beovision 7-55 3D, and this is for the Blurayplayer. I have also checked the settings-menu of the blurayplayer and it is really connected with the internet. BUT, there no update available. Have you made your update thru this ethernet connection?
/Martin
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Sep 21 2012 4:09 PM
Hi Martin,
I had made the update through the ethernet connection to BODTBB47 a few month ago. The actual update to BODTBB52 was made by my dealer a few weeks ago with an USB stick, when he updated my BV 7-40 3D to build 1112 to solve an audio problem.
Probably the update for the bluray player BODTBB52 is not yet online available.
/Räuber
Page 1 of 1 (8 items) | RSS
