How to play "phono" with Beo4, it doesn have a key?
If it`s an older Beo :
search LIST
If it`s a newer one:
N.RADIO
Stefan
N.RADIO? No Phono in list.
Orava: N.RADIO? No Phono in list.
If you can not find PHONO on the list when you select ADD? then you have a more modern Beo4
So select N-RADIO instead of PHONO from the ADD? list
You will find the same IR Code is used - all B&O has done is chnage the label - recognising that LPs were dying as the Internet was arriving
BeoNut since '75
elephant: You will find the same IR Code is used - all B&O has done is chnage the label - recognising that LPs were dying as the Internet was arriving Beo-Ed :-)
francis: elephant: You will find the same IR Code is used - all B&O has done is chnage the label - recognising that LPs were dying as the Internet was arriving Beo-Ed :-) Are you sure about this? On my older Beo 4 I can add PHONO and N.MUSIC. That could result in two different buttons generating the same code??
Beo-Ed :-)
I am remote from my remotes :-( and so I can not check and so I am not 100% sure - I was trying to provide some illumination to Stefan's comments.
I do know that some codes got re-used since I have a couple of Beolink 1000s as well, and you use their keys (often with a simultaneous SHIFT key) to generate a N-RADIO or N_MUSIC command.
But I also don't have my Beoolink 1000 cheat sheet with me as I am traveling :-(
Orava: How to play "phono" with Beo4, it doesn have a key?
From Beo4 manual(hope it helps) see Beo4 manual on-line
When you add a new function to the Beo4 list, you can bring up thisnew ‘button’ in the Beo4 display.> Press and hold the standby button down.> Press LIST to get access to the Beo4 setup function.> Let go of both buttons. ADD? appears in the display.> Press the centre button and use to select AV?, LIGHT? or CNTROL?> Press the centre button to bring up the list of extra ‘buttons’ to add from.The first ‘button’ appears in the display, it flashes on and off.> Press or to move forwards or backwards in the list of extra ‘buttons’.> Press the centre button to add and place the ‘button’ on its preset positionin the list, or …> … press 1 – 9 to insert the ‘button’ at a specific position in the list.> ADDED appears, indicating that the ‘button’ has been added. Long press onBACK will leave the setup.>> Customise Beo4 …36Add an extra ‘button’to Beo4, either to thepreset position or to aspecific position
Don't worry - be Happy
Bob:When you add a new function to the Beo4 list, you can bring up thisnew ‘button’ in the Beo4 display.> Press and hold the standby button down.> Press LIST to get access to the Beo4 setup function.> Let go of both buttons. ADD? appears in the display.> Press the centre button and use to select AV?, LIGHT? or CNTROL?> Press the centre button to bring up the list of extra ‘buttons’ to add from.The first ‘button’ appears in the display, it flashes on and off.> Press or to move forwards or backwards in the list of extra ‘buttons’.> Press the centre button to add and place the ‘button’ on its preset positionin the list, or …> … press 1 – 9 to insert the ‘button’ at a specific position in the list.> ADDED appears, indicating that the ‘button’ has been added. Long press onBACK will leave the setup.>> Customise Beo4 …36Add an extra ‘button’to Beo4, either to thepreset position or to aspecific position
Oh, maybe I should check Beo4 closerly than I have did. Didn´t know it has this kind of functions...
I have prefered Beolink 1000 whenever it is posssible.
PHONO = NRADIO
ATAPE2 = NMUSIC ( = shift Atape on beolink 1000)
Just for info:
On one of my Beo4s (SAT, DVD, with SW version 4.4), you can chose N.RADIO, PHONO, N.MUSIC and A.TAPE2.
On a newer Beo4 (DTV, with SW version 5.0), only N.RADIO and N.MUSIC are listed.
So clearly when the Beo4 first came out B&O appreciated that some people still used the A.TAPE2 and PHONO functions and wanted the correct selection to show on the display when in use.
Guy: So clearly when the Beo4 first came out B&O appreciated that some people still used the A.TAPE2 and PHONO functions and wanted the correct selection to show on the display when in use.
A.TAPE2 and PHONO are my two most-used audio sources! (A.TAPE2 is my Airport Express running through an external DAC).
My A.TAPE2 is for one of these: http://shop.oneremote.dk/catalog/product_info.php?cPath=19_21&products_id=3060
