I am 99.9% convinced that this is a B&O fake make and china.I recently detected the flood of these units at Ebay.uk.http://www.ebay.co.uk/itm/Bang-Olufsen-/232496386130?hash=item3621dd5052:g:2jAAAOSwEotZw-Pq
http://www.ebay.co.uk/itm/Bang-Olufsen-/232496391634?hash=item3621dd65d2:g:eMcAAOSwVgtZw-TR
Those "fakes" are the easiest to spot, as there is no official B&O/Beoplay product corresponding to that!!
diisign.com
Ebay sellers are confident that this is the original product and claim that it was purchased legally in the store.Funny but every week I see at least 20 such ads.
marexy: Ebay sellers are confident that this is the original product and claim that it was purchased legally in the store.Funny but every week I see at least 20 such ads.
Definitely 100% fake!
The seller is called "highcourt12" EBay says This listing was ended by the seller because there was an error in the listing.
with a name like that you'd think he's familiar with legal discussions.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
The spec for each speaker says that they are for "outerdoor"..... a bit of a giveaway apart from anything else.
Graham
I just came across this on Facebook's local buying/selling thing! Was just about to make a new forum post until I saw this one. Tempted to message the seller.
I would never spend more than 50 on eBay unless it was a) obscure b) a crazy good seller feedback or c) collecting in person. If it's B&O your first filter should be "within 50 miles" so you can pick it up and check it's legit.
Can't quite remember,.... but does "Bang & Olufesn" branding blatantly ever appear on BeoPlay products as such?
Earle: Can't quite remember,.... but does "Bang & Olufesn" branding blatantly ever appear on BeoPlay products as such?
The stylised "BANG & OLUFSEN" logo never appears on Play products – only the classic "B&O" symbol is used on them, and only them. On packaging "B&O PLAY by BANG & OLUFSEN" (set in Gotham) has been used, although I'm not sure if that's still the case with the new style packaging.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
tph: Earle: Can't quite remember,.... but does "Bang & Olufesn" branding blatantly ever appear on BeoPlay products as such? The stylised "BANG & OLUFSEN" logo never appears on Play products – only the classic "B&O" symbol is used on them, and only them. On packaging "B&O PLAY by BANG & OLUFSEN" (set in Gotham) has been used, although I'm not sure if that's still the case with the new style packaging.
Yeah exactly - I just checked my E8 packaging and the only mention of "Bang & Olufsen" is in tiny writing on the bottom - just has the B&O Play logo everywhere else.
@ Sheffield,
Yes, 100% fake !!!!
How can you tell they're fake? Easy, the wifi works!
Jeff
Jeff: How can you tell they're fake? Easy, the wifi works!
omg 😂
