Beogram TX working flawlessly except one thing....
This post has 9 Replies | 1 Follower
Zack McCormley
Joshua Tree, Ca
Posts 9
Zack McCormley Posted: Mon, Sep 25 2017 8:48 AM
The tone wont drop on the record.
Everything is perfect on the table but this issue.
Figured before I started poking around. That someone may have a sure shot remedy to get this deck going?
Thanks!!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Sep 25 2017 1:39 PM
Does the tonearm stop and hover over the lead-in groove or just pass over the record and return to park?
Has the tracking force been set correctly?
Zack McCormley
Joshua Tree, Ca
Posts 9
Hi Martin,
The tonearm does stop, and hover over the lead-in groove. The tracking force is set at 1.5g for the mmc 5 Cartridge.
DougH
Posts 9
DougH replied on Fri, Jan 5 2018 1:38 AM
I just pulled mine out of storage and have the same problem..works perfect but arm will not lower. Have you fixed your yet?
Zack McCormley
Joshua Tree, Ca
Posts 9
I have! However, I can’t recall what I did to make it drop. I want to say I made an adjustment to screw of the left of the tonearm.
Sorry I can’t be more help.
DougH
Posts 9
DougH replied on Fri, Jan 5 2018 2:00 AM
I can't locate my manual. Can you be more specific on the screw?
Zack McCormley
Joshua Tree, Ca
Posts 9
Sorry about the delay..... attached is a picture from the 8000 that I used.
DougH
Posts 9
DougH replied on Mon, Jan 8 2018 5:49 AM
Thanks..I found a manual online and it has the same picture. Gonna clean it up and see what happens. Will let you know how it goes.
DougH
Posts 9
DougH replied on Thu, Jan 11 2018 3:39 AM
Update...blew the carriage and area out with low pressure air and used the play and pause buttons. Arm now goes down. Need a preamp now to see how it sounds.
Zack McCormley
Joshua Tree, Ca
Posts 9
GREAT!!
Page 1 of 1 (10 items) | RSS
