Penta3 Powerlink cable
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Tue, Oct 3 2017 1:32 PM
Hello All
I have my Penta3 connected to my Beosound moment with the displays switched off as they do not do much that makes any sense.
From the moment to the first speaker I have a cable from sounds heavenly that is 100% the right one.
As I am moving the other cable was cut away as it was built into the fireplace hearth.
As I m not using the displays will any old cable do?
Sean
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hello Sean,
The Pentas won't usually switch on unless a mk.2 (fully wired) cable is used: http://soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
They need both pin 1 and pin 4 connected to power up the speaker, pin 1 is missing on other Powerlink variants.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
