Mysterious green dot
This post has 7 Replies | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
Hi
There is a mysterious green dot that comes up on the display of a Beosound 3000. It isn't mentioned in the manual and it seems to appear randomly...anyone know its purpose?
Ben
matador43
Posts 1,373
Hi.
Timer function On.
Setup>Arrow down>Timer>OFF.
I keep it on because i like having two dots when the Beosound is off, but it's a matter of taste.
Regards.
matador43
Posts 1,373
Sorry, that sequence is for the Ouverture.
Look in the manual on how to disable the timer. Must be around the timer key !
Cheers…
BenSA
Posts 1,404
BenSA replied on Sun, Oct 8 2017 1:58 PM
Thanks for the info!! I will look into that.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
The different types uses different sequences to turn the timer on or off.
I don't remember it by heart, but on some occasions the Mute button sets the timer on or off (when set is in standby).
BenSA
Posts 1,404
BenSA replied on Mon, Oct 9 2017 8:49 AM
Beobuddy:
A friend is using the Beosound and he asked about the dot, I'll pop around there and have a look at the manual and try and clear the timer.
Ben
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 9 2017 8:53 AM
On my BC2300 it's cleared by pressing MUTE with your unit in stand-by, so that's looking likely as a fix!
BenSA
Posts 1,404
BenSA replied on Mon, Oct 9 2017 9:22 AM
Guy:
Thanks Guy, that sounds like that would be the solution. Will give it a try!
Page 1 of 1 (8 items) | RSS
