Hi
There is a mysterious green dot that comes up on the display of a Beosound 3000. It isn't mentioned in the manual and it seems to appear randomly...anyone know its purpose?
Ben
Hi.
Timer function On.
Setup>Arrow down>Timer>OFF.
I keep it on because i like having two dots when the Beosound is off, but it's a matter of taste.
Regards.
Sorry, that sequence is for the Ouverture.
Look in the manual on how to disable the timer. Must be around the timer key !
Cheers…
Thanks for the info!! I will look into that.
The different types uses different sequences to turn the timer on or off.
I don't remember it by heart, but on some occasions the Mute button sets the timer on or off (when set is in standby).
Beobuddy: The different types uses different sequences to turn the timer on or off. I don't remember it by heart, but on some occasions the Mute button sets the timer on or off (when set is in standby).
A friend is using the Beosound and he asked about the dot, I'll pop around there and have a look at the manual and try and clear the timer.
On my BC2300 it's cleared by pressing MUTE with your unit in stand-by, so that's looking likely as a fix!
Guy: On my BC2300 it's cleared by pressing MUTE with your unit in stand-by, so that's looking likely as a fix!
Thanks Guy, that sounds like that would be the solution. Will give it a try!
