BeoVison 10-46 add info to control with Beo 4 remote
This post has 5 Replies | 2 Followers
Zylog
Posts 2
Zylog Posted: Wed, Sep 26 2012 3:43 PM
Hello all, I am new to this forum so please treat me gently<grin>
As the subject line shows I own a BeoVison 10-46, for family reasons I am simplifying the control systems. Older members of my family cannot get on with the Beo 5 remote so am moving to a Beo 4 remote plus making further changes.
The problem, have got rid of Sky box and moved to a Humax free sat HDR box, very happy with this, but I need to add the code to the TV so that the Beo 4 remote will control the box.  The dealer wants to charge £150 for this.
Being a retired I am sure that it can not be so difficult to do this yourself, given the correct software and codes.
I do not know if this is clear enough, if so I would be pleased to hear from anyone who could help.
Thanks.  Peter.
2012martin
Posts 202
If you go to to settings and then connections and then stb it will bring up a list of 3rd party products already loaded onto the puc list. If your humax box is not there then you will need to get it added. I got told it was £40 for the chip and that was doing it myself. If you want them to do it i am not sure how much it will be. Where abouts are you located? Did you purchase the set brand new? I would of thought your dealer would do this free of charge as a good will gesture
jkhamler
Posts 286
jkhamler replied on Wed, Sep 26 2012 4:21 PM
Zylog - I have this PUC code emailed to me from B&O as this is the STB I use. PM me your email address and I'll send it over. I installed it very easily on my V1 using a USB stick.
Regards,
Jon
Zylog
Posts 2
Zylog replied on Wed, Sep 26 2012 4:36 PM
Hi Jon,
Thanks for the reply.  Being new to the forum I am unable to find how to PM you.  Can you help?
Peter
MartinW
Posts 389
MartinW replied on Wed, Sep 26 2012 5:01 PM
I don't think you will be able to do this without dealer support as, unlike the V1 where you can use USB, the puc codes for BV10 are input via Bang & Olufsen's service tool (laptop, software and some very specific cables, plus a dealer account to access the downloads). £150 sounds like a lot, but i guess that depends how far away from a dealer you are?
elephant
AU
Posts 8,219
elephant replied on Wed, Sep 26 2012 6:19 PM
Zylog:
Hi Jon,
Peter
click on his blue name link above the avatar picture and you should find yourself on a new screen that includes a send email option (personal message = PM)
BeoNut since '75
Page 1 of 1 (6 items) | RSS
