Hello all, I am new to this forum so please treat me gently<grin>
As the subject line shows I own a BeoVison 10-46, for family reasons I am simplifying the control systems. Older members of my family cannot get on with the Beo 5 remote so am moving to a Beo 4 remote plus making further changes.
The problem, have got rid of Sky box and moved to a Humax free sat HDR box, very happy with this, but I need to add the code to the TV so that the Beo 4 remote will control the box. The dealer wants to charge £150 for this.
Being a retired I am sure that it can not be so difficult to do this yourself, given the correct software and codes.
I do not know if this is clear enough, if so I would be pleased to hear from anyone who could help.
Thanks. Peter.
If you go to to settings and then connections and then stb it will bring up a list of 3rd party products already loaded onto the puc list. If your humax box is not there then you will need to get it added. I got told it was £40 for the chip and that was doing it myself. If you want them to do it i am not sure how much it will be. Where abouts are you located? Did you purchase the set brand new? I would of thought your dealer would do this free of charge as a good will gesture
Zylog - I have this PUC code emailed to me from B&O as this is the STB I use. PM me your email address and I'll send it over. I installed it very easily on my V1 using a USB stick.
Regards,
Jon
Hi Jon,
Thanks for the reply. Being new to the forum I am unable to find how to PM you. Can you help?
Peter
Zylog: Hi Jon, Thanks for the reply. Being new to the forum I am unable to find how to PM you. Can you help? Peter
click on his blue name link above the avatar picture and you should find yourself on a new screen that includes a send email option (personal message = PM)
BeoNut since '75
