Opinions of the Beovision 8-32...
This post has 16 Replies | 0 Followers
Tucker
Ponte Vedra Beach, FL, USA
Posts 439
Tucker Posted: Thu, Oct 12 2017 9:06 PM
Hello all!
I am currently planning a complete remodel of my guest bedroom and going to deck it out with some B&O.  The original plan was to have a Beosound 9000 and a pair of Beolab 4000s hanging on the wall, with the Aux from the BS9000 going to a non B&O TV...  However, I found what seems to be a good deal on a Beovision 8-32 with an adjustable wall mount...  This would be my first B&O TV, so I just wanted to ask some opinions on it, especially with the plan being to link it to the BS9000 and the BL4000s.  Let me know what you think!
Thanks!
-Tucker
PS:  Once the guest room is finished you guys are more than welcome to stop in for a visit!
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000,  Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Millemissen
Flensborg, Denmark
Posts 14,680
You will have to get one with a ML module mounted - not all have this.
The sound is pretty good, indeed.
With the BS9000 and the BL4000's it will be fine/even better.
If you get it PUC'ed for an ATV3 box, you should be fine using the HDMI-in - anything else is soso picturewise.
P.S. In Denmark these tv's are almost unsellable - don't pay too much.
Millemissen
Flensborg, Denmark
Posts 14,680
Edit: 'for an ATV4 box' --- of course.
Tucker
Posts 439
Tucker replied on Thu, Oct 12 2017 9:50 PM
Thanks for the info!!  Any easy way to tell if it has a ML Module?  Also what would you consider to be a good price?  There are VERY few for sale in the us, so it is hard to gauge...
Tucker
Posts 439
Master123456789
Posts 237
the white one is a bit more expensive and a bit more rare.
In Denmark the price is on the private marked between 130-220 dollars. The price also depends on there is a digital box with b&o steering, so it can show digital tv-channels with the beo4 remote.
The ML module you can see on the back with the other plugin - on the right site
http://timeless-av.co.uk/wp-content/uploads/2016/08/IMG_1452.jpg
Master123456789
Posts 237
And ENJOY - I love this television. :) :) :)  So bad they don't do it in a 2017 updated version with all the new stuff. But it have hdmi, so you can add on almost anything. The sound is very good also.
Millemissen
Flensborg, Denmark
Posts 14,680
I don't know any specific item number, that would indicate that it has the ML/system module built-in - especially not for the US marked.
But you can easily see that on the back - it includes extra scart as well.
No idea at all what the price could be in the US - others might know.
Tucker
Posts 439
Tucker replied on Fri, Oct 13 2017 12:54 AM
Thanks guys!  I really appreciate the help.  I have asked to make sure it has a MasterLink connection.  The price is $300 for the BV, a Beo 4, and the wall mount. Think that is fair?
-Tucker
elephant
AU
Posts 8,219
elephant replied on Fri, Oct 13 2017 1:22 AM
If you are also getting a beo4 and a stand I would say that sounds fair.
You might also want to configure as a monitor for your guests - I find it very useful as a monitor.
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Fri, Oct 13 2017 1:23 AM
elephant:
And we configured ours for attaching various game controllers !
BeoNut since '75
Tucker
Posts 439
Tucker replied on Fri, Oct 13 2017 1:37 AM
I may have more questions about this if I end up getting it!   My plan is to have a Roku connected and maybe a game console.
moxxey
South West, UK
Posts 5,359
moxxey replied on Fri, Oct 13 2017 10:45 AM
Tucker:
I used to like my 8-32 (which I owned before the 10-32 and was then replaced with a 11-40) in the kitchen.
Only snag is, I found it hard to clean as it was like cleaning a basic LCD panel. No glass, no protection, nothing.
Tucker
Posts 439
Tucker replied on Fri, Oct 13 2017 2:21 PM
Well, I got the BV, Beo 4, and wall mount for $275.  I think that I should be good at that price.  I am looking forward to its arrival and giving it a test run! Smile
didole
Posts 45
didole replied on Fri, Oct 13 2017 7:31 PM
Master123456789:
Indeed I would buy a Beo8-40 with a Beosystem4-like inside (like the Beoplay V1) in a heartbeat.
Master123456789
Posts 237
didole replied on 10-13-2017 7:31 PM
 Master123456789:
__________
yep, but that is more expensive! :) and I also miss it in white.
Tucker
Posts 439
Tucker replied on Sat, Oct 21 2017 8:03 PM
Well the BV8-32 came today!  Unfortunately it does not have the MasterLink connection that I thought it had.  It says "MasterLink" on the back, but there is no plug.  Is this something I could add easily?  Also the "soft touch" finish is a bit beat up.  Has anyone attempted to remove the coating or repaint it?
Page 1 of 1 (17 items) | RSS
DigiCert Secured Site Seal
