How to attach metal bases to Beolab 8000
This post has 7 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Mon, Oct 16 2017 8:02 AM
Hey all,
I know, it's probably stupid (and easy) question, but how do I attach the black metal bases to the speakers? I mean, the speakers slide into the holes but can still be moved. How do you fix them?
Thanks,
Kai
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Oct 16 2017 8:30 AM
The pole has a thread, so how about a nut?
(and a washer, your friendly seller probably kept all these fasteners for some important purpose)
--mika
Manbearpig
Posts 908
Thanks! Yes, seems like it. Do you know the appropriate diameter?
Kai
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Oct 16 2017 10:32 AM
M8 says the service manual. The washer seems to be a split type to help the nut to stay tight, but that’s hardly critical.
--mika
Manbearpig
Posts 908
Thanks very much tournedos, shouldn't be too much of a problem.
I have just compared pre ABL Lab 8000s to post ABL Lab 8000s by the way. Very different sound...
Greetings,
Kai
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Oct 16 2017 9:08 PM
Manbearpig:
Greetings,
Kai
Could you elaborate please? Describe the difference as you heard it? I've always heard the oldest ones sounded different but have never heard in what way. Thanks! My 8000s are from the 97-98 timeframe.
Jeff
Manbearpig
Posts 908
Will do in a separate thread, Jeff.
hemenex
Posts 569
hemenex replied on Tue, Oct 17 2017 8:09 AM
Manbearpig:
But be careful not to use too much force on fastening the nut - the bolt could break as it's a little weak
Been there, done that Sad
  hx
Page 1 of 1 (8 items) | RSS
