My current setup is pretty easy: A Beocenter 2500 in the kitchen and a Beomaster 6500 via Beolab 8000 in the living room controlled via Beolink 1000, 5000 and a MCP 6500.
Now moving to a bigger house I´m thinking of buying a Beosound Essence. Is it possible to connect the Essence to the two existing Beos and stream music from a NAS or Spotify? Could the destination be controlled via App like play song 433 from NAS via Beolab 8000? Which converters will i need, will the BM 6500 maintain full functionality like play independent while the Beosound is playing over the Beocenter Beolabs?
Is there any possibility to add more rooms to such a system? I also have 2 pairs of Beovox rl 140 which could be useful in the garage while working and a few other B&O Loudspeakers for other rooms if that´s possible.
connect the Essence PL to the BM6500 ATape or CD or AUX or...... there is a dedicated cable for it (ask Steve)
the Essence can be set to this setup........than you will have all the Essences benefits
Hello scrooge,
a very good question. I would like to connect a BS Essence (or a BS Core) to Aux-In of a BS9000. Unfortunately neither the Essence nor the Core have a Line-Out. Are there any possibilities?
Digi
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
digi:Hello scrooge, a very good question. I would like to connect a BS Essence (or a BS Core) to Aux-In of a BS9000. Unfortunately neither the Essence nor the Core have a Line-Out. Are there any possibilities? Digi
in the Essence setup; menu Sound - Line Out Level - tick the box: "use Powerlink socket for connection to an audio system instead"
Thank you for this Information
So i could split the signal from the Essence with a Y-adapter and connect e.g. another Beomaster in the garage to the same rj45 powerlink socket?
Are always both powerlink sockets at the Essence used simultaneously or can I switch them on and off if i connect the Beomaster 6500 to #1 and a pair of Beolabs to #2 so i can choose weather the Beolabs should get a signal or not? Or do i have to turn them on and off with a power switch if I don´t want them to play along with the 6500?
In that case the BL’s would always be active/playing, when you use the Essence.
The BM6500 however, only if you push e.g. A.Aux on the remote for that.
Both PL sockets are active (I think it's designed to support 2 speakers that are not daisy chain-able). Therefore, you cannot chose which system gets a signal, but, as you say, you can always turn on/off whatever is at the other end. I have noticed that the connected devices should be turned on when the Essence reboots because it seems like it disables the PL socket if it thinks nothing is connected.
I say this because I have a passive and BLs connected to mine. The passive drives outdoor speakers. I unplug the passive in the winter when I don't use the outdoor speakers. This spring, when I plugged in the passive, it didn't work until I rebooted the Essence...
Just something to watch out for...
Stan
