Beosound Essence compatibility with older B&O stuff
scrooge
Austria
Posts 5
scrooge Posted: Mon, Oct 23 2017 3:15 PM
My current setup is pretty easy: A Beocenter 2500 in the kitchen and a Beomaster 6500 via Beolab 8000 in the living room controlled via Beolink 1000, 5000 and a MCP 6500.
Now moving to a bigger house I´m thinking of buying a Beosound Essence. Is it possible to connect the Essence to the two existing Beos and stream music from a NAS or Spotify? Could the destination be controlled via App like play song 433 from NAS via Beolab 8000? Which converters will i need, will the BM 6500 maintain full functionality like play independent while the Beosound is playing over the Beocenter Beolabs?
Is there any possibility to add more rooms to such a system? I also have 2 pairs of Beovox rl 140 which could be useful in the garage while working and a few other B&O Loudspeakers for other rooms if that´s possible.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Oct 23 2017 6:08 PM
connect the Essence PL to the BM6500 ATape or CD or AUX or...... there is a dedicated cable for it (ask Steve)
the Essence can be set to this setup........than you will have all the Essences benefits
digi
Bremen
Posts 75
digi replied on Mon, Oct 23 2017 6:10 PM
Hello scrooge,
a very good question. I would like to connect a BS Essence (or a BS Core) to Aux-In of a BS9000. Unfortunately neither the Essence nor the Core have a Line-Out. Are there any possibilities?
Digi
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Oct 23 2017 6:37 PM
digi:
Hello scrooge,
a very good question. I would like to connect a BS Essence (or a BS Core) to Aux-In of a BS9000. Unfortunately neither the Essence nor the Core have a Line-Out. Are there any possibilities?   Digi
as described: PL (Essence) to AUX (BS9000).
in the Essence setup; menu Sound - Line Out Level - tick the box: "use Powerlink socket for connection to an audio system instead"
digi
Bremen
Posts 75
digi replied on Tue, Oct 24 2017 6:26 PM
Thank you for this Information Yes - thumbs up
scrooge
Austria
Posts 5
scrooge replied on Wed, Oct 25 2017 2:18 PM
So i could split the signal from the Essence with a Y-adapter and connect e.g. another Beomaster in the garage to the same rj45 powerlink socket?
Are always both powerlink sockets at the Essence used simultaneously or can I switch them on and off if i connect the Beomaster 6500 to #1 and a pair of Beolabs to #2 so i can choose weather the Beolabs should get a signal or not? Or do i have to turn them on and off with a power switch if I don´t want them to play along with the 6500?
Millemissen
Flensborg, Denmark
Posts 14,680
In that case the BL’s would always be active/playing, when you use the Essence.
The BM6500 however, only if you push e.g. A.Aux on the remote for that.
Stan
Chicago-area USA
Posts 869
Stan replied on Thu, Oct 26 2017 10:36 PM
Both PL sockets are active (I think it's designed to support 2 speakers that are not daisy chain-able).  Therefore, you cannot chose which system gets a signal, but, as you say, you can always turn on/off whatever is at the other end.  I have noticed that the connected devices should be turned on when the Essence reboots because it seems like it disables the PL socket if it thinks nothing is connected.
I say this because I have a passive and BLs connected to mine.  The passive drives outdoor speakers.  I unplug the passive in the winter when I don't use the outdoor speakers.  This spring, when I plugged in the passive, it didn't work until I rebooted the Essence...
Just something to watch out for...
Stan
Page 1 of 1 (8 items) | RSS
