After many years of service Ithe left channel passive speaker output became intermittent then failed so no sound from the speaker. The speaker (an S120) is fine - tested on the right channel. What is the likely fix for this? I should add that the MCL rooms are working normally on both channels.
That’ll be the mute relay. A relatively easy fix and plenty of advice if you search the forum
Guy: That’ll be the mute relay. A relatively easy fix and plenty of advice if you search the forum
Indeed there is thank you Guy.
