BC9500 left channel
david707
Posts 146
david707 Posted: Wed, Nov 8 2017 8:47 PM
After many years of service Ithe left channel passive speaker output became intermittent then failed so no sound from the speaker. The speaker (an S120) is fine - tested on the right channel. What is the likely fix for this? I should add that the MCL rooms are working normally on both channels.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Nov 8 2017 11:26 PM
That’ll be the mute relay. A relatively easy fix and plenty of advice if you search the forum
david707
Posts 146
david707 replied on Thu, Nov 9 2017 11:15 AM
Guy:
Indeed there is thank you Guy.
Page 1 of 1 (3 items) | RSS
