Can anyone help.
We had a power failure in the house and now the speakers on the TV are stuck down
Usually when this happens to mine, I simply disconnect the mains (power cord from the Avant) from the wall electrical socket , wait about 1 or 2 minutes, then plug the mains back in. When you turn on the Avant with your remote, the speaker bar usually retracts and the television will restart with "Bang & Olufsen" appearing on the screen.
Gary, I tried this anti install stuck.
any other ideas?
sorry to say that is not fouling
would a factory reset help or is that the last resort?
