Beocenter Overture | Beolink passive | CX100 | CX50
I have Form 1s which were purchased from Lee's shop last year. Lee's shop had restored them with the B&O kit so the pads are in perfect shape.
How can I help?
Great! Since the kit is obsolete I'm thinking of making a drawing of the original foam pads and headrest supports. So I suppose accurate measurements of the two foam pieces on each side. Then some close-up pictures of the same items. Hopefully this could end up as a type of tutorial how to make your own.
Regards,
Mikael
Well, let me do a first draft here.
The piece that sits on the ear is essentially a rectangle.
42 mm up and down
40 mm front to back
7 mm thick
The density of the foam that sits on the ear is a bit less dense than a pair Sony headphones I have sitting here on my desk. The piece that sits above the ear is even less dense.
That piece has a cross section very similar to a stylus. See two posts down.
13 mm at the base
15 mm tall
Tapers down to about 6 mm at the top, which is rounded
35 mm front to back
A second view
And a sketch of the piece that sits above the ear. See how it has the cross section of a stylus (inverted)?
Cleviebaby:Mikael, I have a pair of Form 1s with relatively new pads attached that you can borrow to use as a template. If you pm me your address, I'll post them to you. Cleve
Cleve
Very generous offer of Cleve. I suggest you take him up on it, if for no other reason to "feel" the density of the foam.
A very kind offer indeed! I plan to first find sources of suitable foam material. I will get back to you after that.
Rich: Well, let me do a first draft here. The piece that sits on the ear is essentially a rectangle. 42 mm up and down 40 mm front to back 7 mm thick The density of the foam that sits on the ear is a bit less dense than a pair Sony headphones I have sitting here on my desk. The piece that sits above the ear is even less dense. That piece has a cross section very similar to a stylus. See two posts down. 13 mm at the base 15 mm tall Tapers down to about 6 mm at the top, which is rounded 35 mm front to back
Thanks! Exactly what I was looking for. Next up is trying to find suitable foam material and make some tests cutting it to shape. I was thinking buying bigger foam pads and then cutting them down to size. But if I find the stuff as raw blocks that would even be better. Suggestions are welcome ofcourse.
Restauration project, certainly not perfect but very comfortable...
Philippe
Love = My Beomaster 1001 + Beovox 2700
You don't have a file of this? id like to send it to a friend of mine so hed print me a pair for my form ones since i don't have a 3d printer
Hi. I am not sure if I still have this file hiding somewhere. I still have the headphones. To be honest, the first attempt is not that great. They are not comfortable to wear for a long time. I want to redesign the parts with more flexibility, when I get the time. 3D tech has come a long way since 2015 :). If I find the files, or conjure up new ones. I’ll post to this thread in the future.
