Form 1 foam pad drawing
This post has 13 Replies | 4 Followers
Mikael
Sweden
Posts 58
Mikael Posted: Mon, Oct 1 2012 6:08 PM
Hi, I won an internet auction the other day. It was a pair of Form 1 headphones. Since they (as do many) miss the foam pads they went cheap. I emailed one of the sponsor companies that used to sell the B&O restoration kit. But it seems it is no longer available. So I'm thinking why not try and make my own. Trouble is I don't have any reference to start from. So do any of you guys have Form1 with the pads intact and are willing to take close ups and make a drawing? I saw online that some guy actually did retrofit Form 2 pads with good sounding results but that looks wrong I guess. And does not solve the prism like comfort foam piece above each element. Best regards, Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Tue, Oct 2 2012 5:15 PM
I have Form 1s which were purchased from Lee's shop last year.  Lee's shop had restored them with the B&O kit so the pads are in perfect shape.
How can I help?
Mikael
Sweden
Posts 58
Mikael replied on Tue, Oct 2 2012 8:43 PM
Great! Since the kit is obsolete I'm thinking of making a drawing of the original foam pads and headrest supports. So I suppose accurate measurements of the two foam pieces on each side. Then some close-up pictures of the same items. Hopefully this could end up as a type of tutorial how to make your own.
Regards,
Mikael
Cleviebaby
Exeter, United Kingdom
Posts 672
Mikael,
I have a pair of Form 1s with relatively new pads attached that you can borrow to use as a template. If you pm me your address, I'll post them to you.
Cleve
Rich
Posts 2,598
Well, let me do a first draft here.
The piece that sits on the ear is essentially a rectangle.
42 mm up and down
40 mm front to back
7 mm thick
The density of the foam that sits on the ear is a bit less dense than a pair Sony headphones I have sitting here on my desk.  The piece that sits above the ear is even less dense.
That piece has a cross section very similar to a stylus.  See two posts down.
13 mm at the base
15 mm tall
Tapers down to about 6 mm at the top, which is rounded
35 mm front to back
Rich
Posts 2,598
A second view
Rich
Posts 2,598
And a sketch of the piece that sits above the ear.  See how it has the cross section of a stylus (inverted)?
Rich
Posts 2,598
Rich replied on Thu, Oct 4 2012 12:21 AM
Cleviebaby:
Mikael,
Cleve
Very generous offer of Cleve.  I suggest you take him up on it, if for no other reason to "feel" the density of the foam.
Mikael
Sweden
Posts 58
Mikael replied on Sat, Oct 6 2012 4:25 AM
Cleviebaby:
Mikael,
Cleve
A very kind offer indeed! I plan to first find sources of suitable foam material. I will get back to you after that.
Mikael
Sweden
Posts 58
Mikael replied on Sat, Oct 6 2012 4:33 AM
Rich:
42 mm up and down
40 mm front to back
7 mm thick
13 mm at the base
15 mm tall
35 mm front to back
Thanks! Exactly what I was looking for. Next up is trying to find suitable foam material and make some tests cutting it to shape. I was thinking buying bigger foam pads and then cutting them down to size. But if I find the stuff as raw blocks that would even be better. Suggestions are welcome ofcourse.
boreades
Posts 30
Restauration project, certainly not perfect but very comfortable...
Philippe
Jamian
OREGON, USA
Posts 33
Jamian replied on Thu, Feb 5 2015 5:31 AM
Hi
I got the dimensions off this forum, created hollow geometry and 3D printed in a flexible materialCool I covered the ear pads in fabric, using a technique similar to the CX100s; pinching the material in small slots at the corners. I have tried a few geometries for the head pads. The ones shown are the best so far, but could be more flexible. Shame the 3D printing material is not black.Wink
Love = My  Beomaster 1001 + Beovox 2700
wokbelly
Midwest USA
Posts 39
wokbelly replied on Sat, Dec 11 2021 8:19 PM
You don't have a file of this? id like to send it to a friend of mine so hed print me a pair for my form ones since i don't have a 3d printer
Jamian
OREGON, USA
Posts 33
Jamian replied on Mon, Dec 13 2021 2:50 AM
Hi. I am not sure if I still have this file hiding somewhere. I still have the headphones. To be honest, the first attempt is not that great. They are not comfortable to wear for a long time. I want to redesign the parts with more flexibility, when I get the time. 3D tech has come a long way since 2015 :). If I find the files, or conjure up new ones. I’ll post to this thread in the future.
Page 1 of 1 (14 items) | RSS
DigiCert Secured Site Seal
