I have the following setup on ML:
A BV8-40 as Video Master (option 2)A Besound as Audio Master (option 0)
And some link room setup.
I have attached a BLC NL/ML converter to the ML network to be able to use ML sources on a Beoplay M3 Speaker in another room. That works fine. And also to use TuneIn from M3 on the ML setup. That works also fine as N.Radio.
A bonus with the BLC is that I know also can control my main BV8-40 with the B&O app (at least some of the functionality).
What is weird is that the list of BV8-40 sources is not correct in the B&O. I see TV, Radio, CD, DTV, DVD etc and the NL sources N.Radio and N.Music, but V.MEM is missing from the list to control sources on the BV8 in the App.
I have a Apple TV connected and mapped to V.MEM, but can turn it on from the app.
I saw then that DVD2 also was found a source even noting i connected and mapped to DVD2. I tried to change the mapping of the AppleTV in the BV8 menu to use DVD2 instead of V.MEN that works fine. I can then turn AppleTV on with the DVD2 in the source list in the app, but I do not want that since it is then more difficult on the remote control BL4. I changed the mapping on BV8 back to V.MEM, but V.MEM does still not show up in the source list in the app.
Yes V.MEM is enabled in the configuration for the BLC converter. I have even named it AppleTV in BLC.
Then I also tried to rename DVD to Bluray in BLC just to see if I can see this in the B&O app in the source list. Yes this worked fine immediately.
So why will V.MEM not show up?
When I look on the configuration of BLC in "Sources visible on ML". I seems like something is using DVD and DVD2, but V.MEM says empty.
Connected to DVD I have a Bluray player, but nothing on DVD2.
Under both ML source DVD and DVD2 it says 9517.1856610.23683401@product... I cannot see more. This is in NL product name.
Under DVD it says empty in the same field. But Empty should not be a problem since it says tha same for bout TV and DTV and these works in the B&O app.
On the NL network I have only a Beoplay M3 and the converter.
So how can I get V.MEM on the list of sources in the B&O app?
This is still an issue.
Anyone that can give a hint?
BeoNut since '75
Yes. My tv is already setup this way. The DTV button is used for something else.
It is still a mystery why V.MEM do not show up.
Sorry to bring up this old thread, but now I just added an M3 to my home and love it. I did not realize I may also be able connect this to play sources from my ML system using the BLC. Does that mean all of the sources connected to the BS3/BS6500 integrated system can be routed to my M3? From this thread and the Beolink Handbook it looks like I need the Beolink Converter NL/ML to do this correct? Anything else needed?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
No, nothing else needed - you just need that converter.....and the right settings.
That said - there might be some cases where you’ll need a delay box - informations of which you can find in the BeoLink Handbook.
elephant:PS ... are you aware that if your country has stopped broadcasting analogue television you can disable TV which reassigns the digital broadcast to the Beo4 key and frees up the DTV key for other purposes ?
I can free up the TV key, but how do you free up the DTV key? I am assuming you reassigned DVB to the TV key or ?
