Aussie Michael:And it’s right at the other end of the house with the lowest signal. Never skipped a beat.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Beotool show RSSI -50 for my A6
jimcaj:Yes, it’s a great performer, the A6. I’m very satisfied with the sound and I like the design better and better. Please, some day, if you get the time - would you check the RSSI value for me in the Beotool app? I wonder what yours say, now you have no problems. In the app, press the device, that takes you to the product details panel. There you find the RSSI value. Stands for Received Signal Strength Indicator. I cannot get it to be better than around -70 When it drops the connection it’s worse than -80. Where as my M5 and M3s have much better values, around -50 -40. The M3 is by far the best.
Aussie Michael:-73 But it’s also the farthest away from the router. The a9 is closer at 40
Mine is also CA6, same software level as yours, and RSSI reports as -72 dB (good or excellent in every other display). I haven’t noticed any problems that I could blame on weak wifi connection.
The router is perhaps 6 m away, but it is a ZTE with no external antenna, and it has quite short range.
--mika
