Can I connect my B&O Beomaster 5500 to a Toshiba laptop? As I would like to convert vinyl records to CD's
They do have the huge advantage of having not only DIN connectors but also a full complement of RCA plugs. This actually makes them ideal for present day use as the extra connections allow computer and digital music connections in addition to usual sources.
https://www.beoworld.org/prod_details.asp?pid=354
Hi Herontye,
Welcome to Beoworld!
Yes, you can use the DIN or RCA Tape Out sockets to record from your vinyl records to your laptop. It is often a good idea to add an external USB sound card like this one to improve on the standard 3.5mm microphone input fitted to most laptops:-
https://www.soundsheavenly.com/beogram-record-players/73--ufo202-.html?search_query=usb&results=2
I can include a free 1m twin RCA connecting cable with this on request - please mention that you are a Beoworld member and I will be pleased to add this for you.
I use the free Audacity recording software for digitising vinyl records (available online for download), this has a good choice of filter options to help clean up bad recordings.
Kind regards, Steve.
Steve.
