Beogram 3500 hinge repair
This post has 4 Replies | 2 Followers
TarheelDan
Posts 3
TarheelDan Posted: Thu, Dec 7 2017 6:27 PM
My 3500's dust cover won't stay up. It's because one of the plastic "tabs" in the back corner is broken off.
I have the broken off piece, and have tried epoxy, but it's too weak for the type of stress place on the broken area.
Are there viable repairs short of getting a different dust cover?
thanks,
Dan
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Dec 7 2017 7:25 PM
Beogram 3500?
Sure it's not a Beocenter 3500?
TarheelDan
Posts 3
typo. Beogram 3400
Dillen
Posts 13,191
Dillen replied on Thu, Dec 7 2017 7:46 PM
Oh, completely different then.
Glue together the broken pieces - just to hold them together.
Drill a 2,3 mm hole through the broken pieces.
Insert a 2mm steel pin (steel nail), dipped in strong Epoxy (slow setting type for strength).
Let it set.
Dremel  away any excess metal and glue.
TarheelDan
Posts 3
Thanks! I'll give it a try.
Page 1 of 1 (5 items) | RSS
