My 3500's dust cover won't stay up. It's because one of the plastic "tabs" in the back corner is broken off.
I have the broken off piece, and have tried epoxy, but it's too weak for the type of stress place on the broken area.
Are there viable repairs short of getting a different dust cover?
thanks,
Dan
Beogram 3500?Sure it's not a Beocenter 3500?
typo. Beogram 3400
Oh, completely different then.Glue together the broken pieces - just to hold them together.Drill a 2,3 mm hole through the broken pieces.Insert a 2mm steel pin (steel nail), dipped in strong Epoxy (slow setting type for strength).Let it set.Dremel away any excess metal and glue.
Thanks! I'll give it a try.
