Spotify Connect is now on my BS5!!!
This post has 12 Replies | 1 Follower
Stan
Chicago-area USA
Posts 869
Stan Posted: Fri, Dec 22 2017 11:45 PM
I don't know when this happened, but I opened my Spotify app on my phone tonight to listen to some music.  When I opened "available devices", there was a new listing: "BEOMASTER5".  I selected "N.Music" to fire up the BS9000 + Bs5, selected "Spotify" as the mode, and music came out of my speakers!!!
As far as I'm concerned, this is better than the old Spotify support.  Thank you B&O.
Stan
Sweden
Posts 357
Silver Member
Martin replied on Sat, Dec 23 2017 8:48 AM
Hi Stan, I dont get this to work.are you loged in to spotify in the Beosound 5?
When I start my spotify app I see no Beomaster5.
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sat, Dec 23 2017 9:00 AM
Are you getting coverflow ?
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Dec 23 2017 2:09 PM
I am logged into Spotify with my premium account. This is the account I used back when Spotify worked. The strange part for me is that I didn’t do anything to make this work. One day, Spotify stopped working. Now, it just showed up in my list of devices
No, I don’t get cover flow.
My application version is 7.04.01.1945
Stan
Stefan E
Sweden
Posts 101
Stefan E replied on Sun, Dec 24 2017 12:52 AM
Hi Stan,
Is it still working for you? I´m not able to log on to my Spotify Premium account and it only say no internet connection an problem people have had in the past as well related to the Spotify service been down.
Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
gysse2004
Hellerup
Posts 192
gysse2004 replied on Sun, Dec 24 2017 8:31 AM
Same here, trying to log in on Beosound 5, says “no internet connection”. Although I have the Spotify app running on BM5. That gives you “connect” via A.Aux.
Petet
liberal
Posts 43
liberal replied on Sun, Dec 24 2017 9:42 AM
Same problem here too.
When I check the network info, under the settings menu on my BS5 it ‘checks’ for ages then states that there is no network connection, even though it’s currently streaming Radio 4!
i wonder if the problem lies with the connection to the servers at Bang & Olufsen rather than Spotify.
Best,
Paul
Duels
England
Posts 2,553
Duels replied on Sun, Dec 24 2017 9:51 AM
Same problem here..... “no internet connection” message.
Stan
Chicago-area USA
Posts 869
Stan replied on Sun, Dec 24 2017 2:55 PM
It is still working for me. I do get the “no internet” error, but Spotify and N.Radio still work. Also get the “checking for ages” issue when I go into network settings.
Hmm... As I was writing this, my music stopped, and Beomaster5 has disappeared from my devices list. Sad. I’m also not seeing the Internet error.
Easy come, easy go?
It is possible that this behavior is something left over from prior attempts at running the Spotify app on the bs5. My recollection is that I never got this to work across a reboot and I disabled it, but my memory is not what it once was. However, I definitely do not remember ever seeing beomaster5 in my Spotify devices list.
Stan
Stan
Chicago-area USA
Posts 869
Stan replied on Sun, Dec 24 2017 3:53 PM
So I rebooted the bs5 and my iphone and it still no longer works. I looked at my Android phone, and beomaster5 still showed... then it disappeared Sad
jhamers
Posts 35
jhamers replied on Mon, Jan 1 2018 4:33 PM
This must have been the spotify app you installed at some point that came alive somehow. I'm using the same solution.
No way this is the old integration working again. That one will never come back.
beolion
Posts 485
beolion replied on Thu, Jan 4 2018 12:23 AM
Yes, I agree on that one.
I have Spotify installed manually on the system, and the system has the default name BEOMASTER5 using Spotify Connect.
beolion
Posts 485
beolion replied on Thu, Jan 4 2018 12:25 AM
However, we know that Spotify have turned off the API's that B&O "natively" used to connect to Spotify, but since the installed Spotify on the BM5 Windows XP system is working, I wonder what API the standard Spotify software is using and why B&O cannot use this.
Page 1 of 1 (13 items) | RSS
