I don't know when this happened, but I opened my Spotify app on my phone tonight to listen to some music. When I opened "available devices", there was a new listing: "BEOMASTER5". I selected "N.Music" to fire up the BS9000 + Bs5, selected "Spotify" as the mode, and music came out of my speakers!!!
As far as I'm concerned, this is better than the old Spotify support. Thank you B&O.
Stan
Hi Stan, I dont get this to work.are you loged in to spotify in the Beosound 5?
When I start my spotify app I see no Beomaster5.
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Are you getting coverflow ?
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Hi Stan, Is it still working for you? I´m not able to log on to my Spotify Premium account and it only say no internet connection an problem people have had in the past as well related to the Spotify service been down.Stefan
BS3 DVB-HD, BV7-40 MKIII, BC6-26, BC6-23, BV4-50/BS2, BS5, BS9000, BL3500, MLGW, BLGW, PlayMaker, - BS6500, BS4500, LX6000, VX7000, MX5500, VX5000 - Beo6, Beo5, BeoTimex2, Linctonic
Same here, trying to log in on Beosound 5, says “no internet connection”. Although I have the Spotify app running on BM5. That gives you “connect” via A.Aux.
Petet
Same problem here too.
When I check the network info, under the settings menu on my BS5 it ‘checks’ for ages then states that there is no network connection, even though it’s currently streaming Radio 4!
i wonder if the problem lies with the connection to the servers at Bang & Olufsen rather than Spotify.
Best,
Paul
This must have been the spotify app you installed at some point that came alive somehow. I'm using the same solution.
No way this is the old integration working again. That one will never come back.
Yes, I agree on that one.
I have Spotify installed manually on the system, and the system has the default name BEOMASTER5 using Spotify Connect.
However, we know that Spotify have turned off the API's that B&O "natively" used to connect to Spotify, but since the installed Spotify on the BM5 Windows XP system is working, I wonder what API the standard Spotify software is using and why B&O cannot use this.
