A1 echo with mic / Sound Setup on Mac
This post has 10 Replies | 1 Follower
Dartmoorwal
Posts 6
Dartmoorwal Posted: Wed, Dec 27 2017 9:27 AM
Anyone else having trouble setting the A1 to work with a MacBook or PC when using it as a microphone and speaker for telephone calls or FaceTime / Skype?
I can set the audio to come out of the A1 and it seems the mic works, of a fashion, but the person at the other end says they can hear themselves echoing.
I have the A1 connected to the USB port.
Aussie Michael
Melbourne, AU
Posts 3,730
Dartmoorwal:
I haven’t tried but I will check and see
Yendys
Sydney
Posts 312
Yendys replied on Fri, Dec 29 2017 10:59 AM
My A1 works well on WhatsApp and messenger calls. It has the latest version installed
Dartmoorwal
Posts 6
Thanks Yendys.  Is the A1 connected via USB?  Have you changed settings in "Sound" options on your mac/Pc? If yes, what are Output and Input settings?
Many thanks
gallager
Posts 1
gallager replied on Tue, Nov 3 2020 12:07 PM
Dartmoorwal:
Something similar happened to me. Have you found a solution to your problem?
Barnett
Posts 1
Barnett replied on Wed, Nov 4 2020 8:11 AM
Yendys:
It worked fine for me too until I updated my version of the Messenger's Apps.
gbhouse
Posts 1
gbhouse replied on Wed, Dec 16 2020 10:23 AM
It works well. Thank you buddy for sharing this.
Dartmoorwal
Posts 6
No solution, but seems no longer happening.  Sorry nothing scientific!
riyasen
Posts 1
riyasen replied on Mon, Feb 15 2021 6:23 AM
I was facing same kinda issue with my Macbook pro 2020, i searched a lot on the Internet then finally fixed it after updating the mac.
Technologywell
Posts 1
But it is working well for me for one years...
kuyttendaele
Posts 707
Have been connecting the A1 though USB to iMac/Macbook Pro/Lenovo portable all without problems. On Windows you have to select the “BeoPlay A1 handsfree” in order to have the microphone working.
Karel.
Page 1 of 1 (11 items) | RSS
