Anyone else having trouble setting the A1 to work with a MacBook or PC when using it as a microphone and speaker for telephone calls or FaceTime / Skype?
I can set the audio to come out of the A1 and it seems the mic works, of a fashion, but the person at the other end says they can hear themselves echoing.
I have the A1 connected to the USB port.
Dartmoorwal:Anyone else having trouble setting the A1 to work with a MacBook or PC when using it as a microphone and speaker for telephone calls or FaceTime / Skype? I can set the audio to come out of the A1 and it seems the mic works, of a fashion, but the person at the other end says they can hear themselves echoing. I have the A1 connected to the USB port.
Thanks Yendys. Is the A1 connected via USB? Have you changed settings in "Sound" options on your mac/Pc? If yes, what are Output and Input settings?
Many thanks
Dartmoorwal: Anyone else having trouble setting the A1 to work with a MacBook or PC when using it as a microphone and speaker for telephone calls or FaceTime / Skype? I can set the audio to come out of the A1 and it seems the mic works, of a fashion, but the person at the other end says they can hear themselves echoing. I have the A1 connected to the USB port.
Something similar happened to me. Have you found a solution to your problem?
Yendys:My A1 works well on WhatsApp and messenger calls. It has the latest version installed
It worked fine for me too until I updated my version of the Messenger's Apps.
It works well. Thank you buddy for sharing this.
No solution, but seems no longer happening. Sorry nothing scientific!
I was facing same kinda issue with my Macbook pro 2020, i searched a lot on the Internet then finally fixed it after updating the mac.
But it is working well for me for one years...
riyasen: I was facing same kinda issue with my Macbook pro 2020, i searched a lot on the Internet then finally fixed it after updating the mac.
