Hi
I am trying to use a pair of Beolink Wireless 1 units! I am having no luck. One is set as a transmitter, the other as receiver.....I press the CON button on both of them, they connect, lights are both green. 20secs or so they go to red which I presume is standby mode. The transmitter is connected to a Beosound 3000 via Masterlink cable...then then I have a pair of Beolab 4000 speakers on the receiver. when I turn the Beosound on nothing happens, the lights just stay red? Are the Wireless units faulty? I have swopped them around, same response!
I thought it would be an easy setup...not so much. Any help for me?
Ben
**edit...I see I am supposed to use an IR? I don't have one of those therefore it renders it useless? Which IR does the system use?
Yes you need to connect an ir eye in order to use it as a wireless beolink active. Any b&o eye with din plug will so.
Thanks for the info.....2nd dumb question I've asked tonight!!!
No worries :-) It's not a dumb question just Because you figure it out yourself.
One more question...apparently the Beolab 3500 MK1 won't work with the Beolink wireless 1, if I have an IR will the Beolab 3500 then work?
If you have a system that can be ser to opt. 6 you can use that as the ir eye.
Why won't the mk1 work?
Kromer: Why won't the mk1 work?
I was told that the Beolab 3500 Mk1 does not work with the Beolink wireless 1 as it doesn't have the software for that.....only the Mk2 has??
From a previous posting I found this from Keith Sanders who's the tech advisor for this site.
Let me give you an overview of Beolab 3500 and Beolink Wireless.
First the Beolab 3500 has two variations:-
The Beolink Wireless requires version 2.0 or above for full Masterlink capability and the latest version is version 2.1
Which means if it is a Beolab 3500 Mark2 it will not work via Masterlink unless you update the software in both the wireless 1s and the Mark2 to the relevant software .
Thanks for the Stoobietoo. Thats what I thought. Pity.
How do you tell if your BL3500 is a mk1 or mk2?I'm asking since I am considering a Wireless 1 / BL3500 combo upstairs in my house.
You need to check the serial number.
Beolab 3500 MK 1 up to serial no. 1934xxxx
Beolab 3500 MK2 above serial no. 1934xxxx
