Beovision 7-40 hdmi to dvi Adapter
This post has 10 Replies | 2 Followers
Nikolay
Posts 7
Nikolay Posted: Sat, Dec 30 2017 6:52 PM
hi everyone,
I am new to this forum, and since I’ve not been posting on many forums, I hope I do this right. I just bought a Beovision 7-40 MK2, and I’m struggling getting a picture from my set top box. I have bought a hdmi to dvi Adapter from Amazon, all is plugged ok, but no picture. I’ve tried reading on the Internet as to what may be the cause of that , and there are notes regarding the set up of the actual port. I understand this is done through the connections menu on the tv, but still no luck. Is there a step-by-step guide for what needs to be done, or can someone please advise. I have yet to overcome the sound issue, which again I’m not sure if there will be one, as I see people using sky tv without any problems?
many thanks
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Dec 30 2017 6:53 PM
Make sure Sky Box is set to 720p resolution. Might need another TV to do so.
CB
> You are Here <
Posts 1,762
CB replied on Sat, Dec 30 2017 7:03 PM
Hi and welcome to Beoworld Smile
Are you sure your BV is HD Ready ? (I've had the same problem with my BV6-26 mk1...)
I understood the definition of the screen isn't enough to show a broadcasted HD picture, it must be equipped to decode HDCP signal (copy protected content).
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Dec 30 2017 8:15 PM
Forgot the welcome....
So: welcome!
For HD ready check this link:
http://bogo.custhelp.com/app/answers/detail/a_id/2646/~/which-bang-%26-olufsen-televisions-qualify-as-hd-ready%3F
Ralf
Nikolay
Posts 7
Nikolay replied on Sat, Dec 30 2017 11:01 PM
Thanks for that, only it’s not a sky box but just a off the shelf freeview
Nikolay
Posts 7
Nikolay replied on Sat, Dec 30 2017 11:11 PM
Thanks for the link - it turns out the tv is HD ready, so far so good, but still no luck . What Ive been doing so far is to switch the tv on,select tv>menu>options >connections>AV4=PC . Once selected, sub menus for AV 4 = source, audio socket , IR socket and HDTV. When the latter is selected I am then given the option of either NO , DVI-I or YPbPr. Is this right, am I on the right track? Any suggestions are most welcomed
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Sun, Dec 31 2017 9:02 AM
Hello Nikolay,
first you have to put your freeview box in 720p output mode. Your BV is limited to this resolution. Most boxes have 1920p as standard output mode.
You need to have another (newer) tv to connect the freeview box and put it in 720p mode. Then reconnect it to the BV.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Nikolay
Posts 7
Nikolay replied on Sun, Dec 31 2017 12:16 PM
Hi Martin,
thanks for the advice, did what you said I should, and still no luck 😢, in the connections menu have re-named a port, or how did you allocate it to recognise the source that’s coming in through the dvi?
Many thanks
CB
> You are Here <
Posts 1,762
CB replied on Sun, Jan 7 2018 4:36 PM
Hi Nikolay,
You also have to modify the Beo4 menu in order to have PC available in the list.
Then, you start your BV by pressing List on the remote until you see PC, then Go.
Nikolay
Posts 7
Nikolay replied on Sun, Jan 7 2018 9:59 PM
It worked!!! I added a new button - PC- in the LIST menu and it worked!!! Thank you
Nikolay
Posts 7
Page 1 of 1 (11 items) | RSS
