Easy to remove the floor stand on a BV 8-40?
Master123456789
Posts 237
Master123456789 Posted: Sat, Jan 6 2018 5:09 PM
I have just bought a Beovision 8-40 and my mom will pick it up for me. It is with floor stand - it that easy to remove? Is it just like the wall mount on a Bv 8-32 or 8-26?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Sat, Jan 6 2018 5:58 PM
It's easy, just four screws. But: Removing is best done with two persons. One holding the TV set and the second will remove the 2 screws on the left and the other two on the right. Then the TV can be lift off the floor stand. To operate the screws you need a TORX T15.
And try to get the original delivered table stands too :)
Ralph-Marcus
Master123456789
Posts 237
Thank you - just the answer I needed. Good to know precisely the screws also :-) There will be two persons to removing it.
Page 1 of 1 (3 items) | RSS
